Any news when Sonique will work again for Audio only files?
I want to use VDJ8 live next week, but I have too many audio only MP3's and the screens will look poor with nothing being displayed on them (yes I do photo's in-between sometimes), but sonique goes in-time with the music.
Just wish Milkdrop would work too.
Cheers.
Cheers.
geposted Tue 13 May 14 @ 5:41 am
You can put sonqiue SVP files straight into the Visualisations folder.
Also;
https://virtualdj.com/addons/16711/Milkdrop.html
Also;
geposted Tue 13 May 14 @ 5:42 am
To enable audio only visual
config -> options -> select advanced -> videoAudioOnlyVisualisation
geposted Tue 13 May 14 @ 5:43 am
how do you do that?
I can't seem to get my sonique to work in Vdj8.
geposted Fri 23 May 14 @ 12:27 pm
I created a folder inside /MyDocument/VirtualDJ/Plugins/Visualisations called /Sonique
I then put all my sonique files inside
Then inside VirtualDJ:
geposted Fri 23 May 14 @ 12:55 pm
When I activate Sonique the plugins just keeps restarting every 10-20 seconds. Is there a way to control this.
geposted Fri 23 May 14 @ 1:49 pm
Thanks for responding,
But i don't no skawt about pc's
How do i make this folder and step by step guide would be more helpful please.
geposted Fri 23 May 14 @ 1:51 pm
Also Lots of info is not in the manual. Sort of incomplete!
geposted Fri 23 May 14 @ 2:03 pm
If everything was in the manual it would be 1,000+ long. The WIKI is being updated and that should resolve most of the issues of lack of information.
You make the folder in Windows Explorer - the same as any folder?
I can do some screenshot walkthroughs if that will help?
geposted Fri 23 May 14 @ 3:01 pm
When i followed the screen shots it would not turn of sonique, so back to the drawing board. had to uninstall .
geposted Fri 23 May 14 @ 11:04 pm
