Ignore button keeps vdj running
Abort produces terminated prog notice click ok crashes vdj
Retry crashes vdj
Only started happening after latest update
geposted Tue 13 May 14 @ 7:14 am
Retry crashes vdj
Retry crashes vdj
had this crop up a few times too
geposted Tue 13 May 14 @ 7:22 am
Make sure you're running the latest build.
geposted Tue 13 May 14 @ 7:23 am
It used to run fine on earlier builds , I opened the software and it updated before opening, build was 1751.628
geposted Tue 13 May 14 @ 7:14 pm
this is most likely an old bug from earlier today, that was already fixed..
your VDJ version should already be updated by now hopefully
geposted Tue 13 May 14 @ 7:24 pm
yes confirmed solved :)
Cheers
Cheers
geposted Tue 13 May 14 @ 9:17 pm
