I noticed when playing Mp4 I am hitting over 1 Million Kb , Now the same song in VJ 7.4 is hitting only 234,000 Kb . because I could go in and change the Memory to a different number . But VJ8 you cannot do this ? Need a bit of help here on what to do to change this ?
geposted Tue 13 May 14 @ 11:17 am
Hello anyone want to answer this ?
geposted Tue 13 May 14 @ 1:25 pm
Can you download the new version of FPS for VDJ 8 and then upload here a screenshot when you have the issue
http://www.virtualdj.com/addons/12763/FPS.html
geposted Tue 13 May 14 @ 2:45 pm
Here is a Screen shot
geposted Tue 13 May 14 @ 3:14 pm
sorry here is a bigger shot
geposted Tue 13 May 14 @ 3:16 pm
Did you find any information out for me yet >
geposted Tue 13 May 14 @ 5:50 pm
You can change the Max Video Memory same as VDJ7 and previous. However VDJ stores it in it's own settings file instead of sharing the registry with VDJ7.
If you go into config in VDJ8 and tick the show advanced options bit and you can change the max video memory used under the video tab. By default it is on Auto. Just enter what you changed the registry value to in VDJ7.
geposted Tue 13 May 14 @ 6:08 pm
I need a screenshot of this
geposted Tue 13 May 14 @ 6:17 pm
thx dude !
geposted Tue 13 May 14 @ 7:01 pm
you graphics hardware ?
geposted Wed 14 May 14 @ 12:41 am
