Topic: Auto mix
OK I have been playing with automix and poi and obviously there is a bit of a learning curve to tackle this. My question is two fold...
1. When using Automix does it take into account the settings previously made in the POI editor?
2. While in automix; am I to assume that the only way automix will read the automix info is when in auto mode?
Thanks in advance for your help. VDJ 8 is the sh**!!!
geposted Tue 13 May 14 @ 2:30 pm
bump
Yes to both questions.
What is a nice feature of Automix is.
If you create you playlist.
Automix Editor it to you liking.
If you then save the playlist. VDJ will also remember you Automix edits and load then next time too.
