Topic: ShowLogo not saving setting
I am using the showlogo plugin, when I first used it I set the picture to the bottom right hand corner and adjusted it to where i wanted it to be, I then closed VDJ and its lost all the settings. Does this need to now be setup every time i start the programme or have i missed something perhaps?
geposted Tue 13 May 14 @ 3:23 pm
I tried it and it did save my setting from the last time? Not sure why it didn't save them for you, but so far when I close VDJ8 and activate it again, it saves all my settings! Not sure if logging out would change this? Try just closing it and not logging out, if that's what you are doing?
