I know how to add samples to the pads, but how do you remove them? Thank you Team Atomix!!!! :)
geposted Tue 13 May 14 @ 5:53 pm
Quick way:
Hold CTRL on your keyboard and click the pad you want to delete.
geposted Tue 13 May 14 @ 5:54 pm
Thank you very much for that fix! Greatly appreciate it! :D
geposted Tue 13 May 14 @ 5:57 pm
One more question DJtouchDan! Will there be more video samples for the video & Scratch pads?
geposted Tue 13 May 14 @ 6:03 pm
Question:
Is the appearance of the two sampler views set in stone, or can it be added to/changed via skinning?
I'm thinking waveforms for each sample, proper skeuomorphic faders next to each pad, that sort of thing.
geposted Tue 13 May 14 @ 6:04 pm
can be skinned yes , and a lot same as that..
sampler waveform is not added yet, but will hopefully come .. for now it has a progress bar only
(that being said you could probably even do quite a lot of the above image using decks, vdj supports 99, since v7)
geposted Tue 13 May 14 @ 6:08 pm
Probably for launch that'll be it.
You can record video loops from your decks though.
Tayla has a FREE website for VDJ users with some video samples in http://www.virtualdj.com/forums/187454/General_Discussion/Get_Video_Visuals_for_your_Sample_Banks.html
geposted Tue 13 May 14 @ 6:09 pm
:D
geposted Tue 13 May 14 @ 6:40 pm
