I cant seem to figure out the proper setup in vdj8 to get it to work
geposted Tue 13 May 14 @ 6:19 pm
You'd need to choose "external mixer" then setup up each deck to use a different pair of HC4500 outputs.
So set deck 1 to use HC4500 ASIO channels 1&2 then deck 2 to use HC4500 channels 3&4 for instance.
geposted Tue 13 May 14 @ 6:33 pm
thanks i got that part working is there a way that i can get the info to show on the hc4500 screen
geposted Tue 13 May 14 @ 6:53 pm
