Is there a setting in the browserColumns that will allow for more than 30 results in a search?
geposted Tue 13 May 14 @ 6:22 pm
in database search? i have unlimited ..
geposted Tue 13 May 14 @ 6:35 pm
I think he means online results.
geposted Tue 13 May 14 @ 6:36 pm
exactly...when doing a contentUnlimited or Netsearch its only bringing back 30
geposted Tue 13 May 14 @ 6:37 pm
I would suggest being more specific with your search criteria.
But i hear what your saying - it does limit to 30.
geposted Tue 13 May 14 @ 6:38 pm
no config setting to expand that to more than 30?
geposted Tue 13 May 14 @ 6:41 pm
ah yes, CU results give a limited range. Not sure that can be changed
geposted Tue 13 May 14 @ 6:42 pm
