Anytime I load a song on the right channel it starts automatically anytime I move the fader to the right. It behaves like a fader start feature except moving the fader back to the left does not stop track on the right. The left channel does not have the same behavior. I am on a Mac with OSX 10.9. 2 and a Vestax VCI-400. The behavior started today after the latest update.
geposted Tue 13 May 14 @ 6:41 pm
please check your faderStart settings
It is possible to have one deck on and one deck off
geposted Tue 13 May 14 @ 6:56 pm
Where are the fader start settings located?
geposted Tue 13 May 14 @ 7:37 pm
config -> options -> select advanced
geposted Tue 13 May 14 @ 7:44 pm
Thank you. One more quick question. How do I stop it from automatically syncing the tracks?
geposted Tue 13 May 14 @ 8:30 pm
config -> options -> advanced
autoBPMMatch
autoBPMMatch
geposted Tue 13 May 14 @ 8:31 pm
Thanks again.
geposted Tue 13 May 14 @ 9:10 pm
