I saw in the last update that we have backspin effect. How do i get it?
geposted Tue 13 May 14 @ 7:16 pm
Open VDJ 8!
Updates are downloaded in the background, then when you restart VDJ 8 it'll notify you and ask if you'd like to update.
geposted Tue 13 May 14 @ 7:18 pm
yea did that already but nothing. I removed the effect from the folder because of the error notices i was getting. now after the update i put it back to see if i will have it but i still don't see the option under effects. neither is there a new one in the new vdj8 folder with all the native effects
geposted Tue 13 May 14 @ 7:20 pm
Just so you know my updates were not so "in the background" I got a dialog box that told me updates were availlable and when they were done the screen flashed and I was back to default settings. Font size, folders, browser columns were all back to default.
geposted Tue 13 May 14 @ 7:27 pm
mine remained the same just that i still don't have my beloved backspin. I will attach two print screens
geposted Tue 13 May 14 @ 7:34 pm
geposted Tue 13 May 14 @ 7:35 pm
I think something was said about certain effects not being compatible with VDJ 8, and so they're disabled from loading.
geposted Tue 13 May 14 @ 7:37 pm
Well in the new update they said the action is added i assume they are talking about the effect
geposted Tue 13 May 14 @ 7:40 pm
