Topic: bug Virtual Dj8
When you try to delete a file by right clicking it, the software shuts down.
Under the file operations,.
or on the recorded tab
geposted Tue 13 May 14 @ 10:28 pm
Please specify your Operating system.
Is this happening with all your files ?
and what exactly do you mean by the "recorded tab" ?
Not sure if this is a bug or not.. Trying to run a 4 deck mixer and since i didnt see anything on changing between decks in the user manual I assumed it was still the tab key... when i press tab it will switch between channels 2 and 3 but not to 1 and 4... Am i missing something or is this a tech issue...
the tab key should toggle the selected deck between decks 1 and 2.
What mixer are you using ? an analogue dj mixer or some controller ? what exactly do you wish to achieve , make a deck selected or swap the left-right decks ?
No controller at this time, havent hooked it up to v8 yet, just using the keyboard on my office pc... just want to be able to go from deck 1 to 2 to 3 to 4 without having to click on the deck with the mouse....
Ok, reported.
Thank you for noticing
