Hi, I have noticed that when I load a track to vdj 8 it analyses the bitrate incorrectly. It used to do it correctly in version 7.
I always have bitrate showing in the main browser so I know I am going to be playing a high bitrate track. I will try to post a screenshot where you can see that the bitrate for songs that I have played goes into 4 digits. This cannot be correct.
geposted Wed 14 May 14 @ 1:45 am
.png)
Here you can see some songs are around the 320 mark which is correct, while the others (ones I have played with VDJ 8) are showing between 3000 and 5000 bitrate!
geposted Wed 14 May 14 @ 1:49 am
          reposting cropped screenshot
       geposted Wed 14 May 14 @ 1:51 am
          It is right . 720 or 1080 videoclip not have low Bitrate
it is easy open you file in explorer (right click and you look to bitrate .. it to same )
I see this file is from VJPro . right bitrate
geposted Wed 14 May 14 @ 5:41 am
          Ok I see now, it is showing the video bitrate in kbps. However, it should be showing the audio bitrate. That is what is important to a DJ and that is what vdj 7 used to show. Hence, you can see the songs that have a 3 digit bitrate are from the version 7 info.
    geposted Wed 14 May 14 @ 2:26 pm
          Hey VDJ team, any chance of seeing audio bitrate for videos? It's kind of important.
    geposted Sun 18 May 14 @ 9:23 pm
