Topic: mouse scrollwheel back to front
A possible minor bug I just spotted - when adjusting the onscreen pitch faders using the scrollwheel on a mouse, they operate back to front, ie you scroll down, and the pitch fader travels upwards. A tad confusing!
geposted Wed 14 May 14 @ 11:57 am
The fader may move up but the pitch is going down - the same as it has always done.
I kind of see the logic, scrolling up to make the pitch go up, but then compare it to adjusting a volume fader on the same skin, which works the opposite way. I'd have thought it would make sense that all faders should operate in the same way using a scrollwheel.
