Hey Team !
I use a full Pioneer CDJ - DJM 2000 Kit and have tried the CDJ´s with some mapping with great results.
But I have problem to find a mapper for DJM2000.. have I missed it ?
Would like to use it like (3-1-2-4) like the mixer is build.
I have tried all old mappers for the 2000´s on the site and it didnt work so great :-(
Anyway thank you for a great update !
geposted Wed 14 May 14 @ 12:29 pm
          i tried to map the djm 2000 my self and it still does not work . i don't think the mapping is working
    geposted Wed 14 May 14 @ 1:04 pm
          What are some of the problems you having, my problem is... I move tbe left vol slidder and right slider vol moves, I havent even have option to chose left deck or right. This is with my djm 700 HID connection
    geposted Wed 14 May 14 @ 8:58 pm
          The problems is different between the "old" mappers I have tried.
Mostly I would like to control through MIDI/HID the channel fader, the crossfader (synced with Video crossfader ;-) and the bass, mid, treble and filter knobs.
AND use the settings mainly for Channel 2 & 3 on the mixer (config 3-1-2-4)
But it would be nice to see if it can be a original mapper in the program soon !
ANY response from the TEAM would be nice ?
geposted Thu 15 May 14 @ 10:19 am
          When I setup the channels get wrong what I even trying to do.
When I setup 3124 in one mapper from V7, the channel 2 is 1 on the mixer and channel 2 is 2.
The right setup with 3124 should be channel 1 as 2 and 2 as 3 on the mixer, right ?
What am I doing wrong, Help neded !!!
geposted Fri 16 May 14 @ 5:49 am
          Bumping this because I dont get any answer from the staff ?
I would likely use this PRO Setup if its possible !
geposted Mon 19 May 14 @ 4:09 am
