Topic: Video onto 2nd screen
Just been trying to get video screen onto 2nd monitor and I can't find anything in the options to use 2nd screen I've put my vdj 7 pro serial in but it's just going full screen onto my laptop and if I reduce it part on both screens but can't move it, I'm currently using MacBook Pro with mavericks
geposted Wed 14 May 14 @ 1:56 pm
I don't know how it works on a Mac, but if you double click the video, it should turn into a window. You should be able to grab the top, and drag to second monitor. There you double click, and it will fill the screen. The top may be hidden, so you may have to fish for it. After the first time, it should be OK.
Cheers fella I'll try at home at a gig now lol
