Topic: zip files & KARAOKE [SOLVED]
I notice that my newer Karaoke that is zipped does not play with VDJ8 But does in VDJ 7.4?? any ideas THX.....
geposted Wed 14 May 14 @ 5:12 pm
Don't play ?
OR you mean they don't appear on browser ?
they don't appear & DONT PLAY from dragging them from the actual file to either deck also
in options, check "show advanced settings", search for showkaraokezip,. and set to yes
YES THANK YOU !!! you guys ARE AWESOME
