Topic: Major Issue!!!!
Just found this issue while setting up my laptop. I have a maya 44 USB ... Its 4 in and 4 out. I have deck 1 assigned to output 1&2 and deck 2 assigned to output 3&4. Now I want to use a 4 deck skin like I do in 7.4. So, I assign deck 3 to output 1&2, so there are 2 decks assigned to output 1 &2. I do the same with deck 4. I assign to outputs 3&4. Now When I play deck 1, no output. BUT deck 3 has output. same with decks 2&4. This setup works fine in 7.4. How can we fix this?
Thanks....
geposted Wed 14 May 14 @ 8:38 pm
No one?? There has to be someone who can help with this issue....
geposted Thu 15 May 14 @ 3:30 pm
One of the team will look at this in due course.
OK.. I hope soon :)
geposted Thu 15 May 14 @ 3:36 pm
JeremKPRO InfinityModeratorMember since 2004
I have a maya44 and will be able to test this week-end.
Are you on Mac OS or PC ?
geposted Thu 15 May 14 @ 3:49 pm
PC windows 8.1 with latest maya asio drivers. Its like assigning more then one deck to a set of outputs kills the sound from the first deck even though the on screen mixer shows there is sound, the lights on the maya do not work. I can play sound from the second deck on the same channel. As soon as I remove the 2nd deck assigned to the channel from the config, the first deck is working again....
geposted Thu 15 May 14 @ 7:07 pm
Could you please post a screenshot of your Audio Setup here please ?
geposted Fri 16 May 14 @ 3:16 am
sorry I cant right now but here is what I have
Deck 1 = Maya output 1 & 2
Deck 2 = Maya Output 3 & 4
Timecode Deck 1 = Maya input 1 & 2
Timecode Deck 2 - Maya Input 3 &4
That works fine.. now if I switch into 4 deck mode and assign Deck 3 to Maya output 1&2 and deck 4 to Maya output Deck 3 & 4 ... Now only Deck 3 & 4 have sound and NOT deck 1 & 2 .. This worked fine in V7.. in V8 I can switch the timecode on and off for which deck I want to use...
geposted Mon 19 May 14 @ 11:41 am
I did notice if I assign Deck 3 to Maya input 1 &2 for timecode and Deck 4 for 3 &4 input for timecode I can select which deck I want to use timecode with. Just the output only works on deck 3&4 until I remove the assignment from the config...
geposted Mon 19 May 14 @ 11:44 am
Has this issue even been looked at?
geposted Wed 21 May 14 @ 3:30 pm
OK So I am guessing NO one has looked at this issue... I have been just using 2 decks waiting for a solution...
geposted Sat 24 May 14 @ 10:41 pm
anyone??????
geposted Fri 30 May 14 @ 10:29 am
It should have been fixed a few builds ago. Are you using build #1820?
geposted Fri 30 May 14 @ 10:33 am
Im using the latest. I havent tried 4 decks again as I never knew this was fixed.. is it in the version release notes somewhere?
Can I use 4 decks WITH timecode and select which decks I want timecode to go onto?
geposted Fri 30 May 14 @ 10:38 am
