Just started getting this...
Any Help?
Here is details
Any Help?
Here is details
geposted Wed 14 May 14 @ 8:50 pm
I'm not a Developer - but this is usually driver related and not software related.
Have you installed any new hardware or updated drivers recently?
geposted Wed 14 May 14 @ 8:53 pm
no brother v7 works flawlessly
Just started doing this
geposted Wed 14 May 14 @ 8:56 pm
What were you doing when it happened?
geposted Wed 14 May 14 @ 9:00 pm
Video and karaoke
geposted Wed 14 May 14 @ 9:01 pm
Have you been able to re-produce it?
geposted Wed 14 May 14 @ 9:03 pm
Yes it happens everytime kinda wierd
geposted Wed 14 May 14 @ 9:05 pm
geposted Wed 14 May 14 @ 10:48 pm
First thing I would recommend regardless of the version of software is to check if you have any updates for your video card driver.
geposted Wed 14 May 14 @ 10:52 pm
Current driver offered
geposted Thu 15 May 14 @ 12:18 am
Did you install directx 9.0c too?
If not, please do that and try to reproduce.
geposted Thu 15 May 14 @ 3:38 am
Can you assist in how to downgrade?
geposted Thu 15 May 14 @ 3:37 pm
here are the links you need....
DirectX 9C Runtime: http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
DirectX 9.29.1974 End-User Runtimes (June 2010) http://www.microsoft.com/en-us/download/details.aspx?id=8109
Microsoft VC++ 2008 Runtime Libraries: http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
geposted Thu 15 May 14 @ 3:39 pm
It isn't a downgrade. Some of the plugins and effects user components of DX9 which aren't present in DX11.
Thats all it is. You have this links from RobRoy above - just run the installers.
geposted Thu 15 May 14 @ 3:50 pm
So Far so good!!!!!!!
Thanks baby white jesus !!!!
crossing fingers
crossing fingers
geposted Thu 15 May 14 @ 6:02 pm
ok if i delete all the code from the first post your sorted? tidy it up a little bit.
geposted Thu 15 May 14 @ 6:05 pm
Sure
geposted Thu 15 May 14 @ 7:52 pm
New error just popped up after dx 9 install
geposted Thu 15 May 14 @ 7:54 pm
After DX9 Install and a hour of pounding it.
geposted Thu 15 May 14 @ 8:02 pm
Maybe this will help?
http://repairerrors.net/0x000000f7.html
geposted Thu 15 May 14 @ 8:24 pm
