Topic: Bug Time REMAIN
On OSX, on Deck B, the time remain moves (the text moves when the last digit is 1), on Deck A it's fine..
geposted Thu 15 May 14 @ 3:09 am
I'm using Build 1910.766 on my 15" MacBook Pro and this issue still exists. This would seem like an easy bug to squash.
i think this is down to the skin resizing as i can recreate this on a PC..
Its not a gig-stopping issue though..
any news about this?
Annoying to see for sure but certainly not a bug.
This has nothing to do with the function of the software.
There's a number of issues with the default skin. (This is just one of them...)
You may be able to fix that yourself if you edit the xml.
