Topic: xp with v8 - Page: 1
seems like the the CrAcKiNg is back to haunt me.... but this time im getting constant crackings through out the entire track.
any thoughts?
geposted Thu 15 May 14 @ 4:58 am
without any details about your system, specs and settings....honestly ....no....;-)
LOL
XP
asus f5 entertainment system
core 2 duo
nothing special... it was my 1st gig machine
ohhh, using cdj 400's
OK, what audio interface are you using? "External mixer" setting and the CDJs as sound cards?
iv just switched to 7.4 and everything running ok... im going back to V8 now... BRB
ext mixer and cdj 400 and 2 deck interface
I assume you're using the Pioneer ASIO driver. What's the buffer set to?
What are your ASIO related settings in VDJ 8?
ummm, wheres that in V8??
face palce
Where's the buffer, or where's the ASIO setting in VDJ?
Please, don't make me get my CDJ-400s out. :-)
If your soundcard is recognized you should see a small "Asio" labled pic in the soundsettings.
Just click on that.
asio settings, i don't know where it is, i cant find it.
buffer is automatic
in card, i see
internal sound
two sound card
sterio to mono
and pioneer
Maybe today I will try VDJ 8 on XP with my two CDJ-400s (later).
no rush... i just wanted to try out my xp with my djm 700 but with the music not working i cant fix my other problems that im having
As much love as I still see for XP, be aware guys, that the platform is no longer supported by MS, and (system) patches no longer are built. 7 should run fine on the same HW as XP without problems (especially a dedicated box for VDJ)
Go into config.
Tick the box to enable advanced options (top right).
In audio options turn off (set to "no") the Ultra Latency option.
On my Asus lappy got same issue get static crackles and can just hear song in back ground.But i put VDJ8 on Desktop PC changed no settings works like a dream.
But i am not using a controller just going through earphone channel like i have with VDJ7.
So seems i need to fork out some cash and get me a controller now......oh happy days of dj'ing lol.
And My lappy is running on windows 7.But to save any problems with other programs slowing VDJ down i use a Gaming mode which closes programs that are not needed to use VDJ :)
Have you tried enabling wasapiSharedMode in the advanced config menu?
apologies if you have - i did quickly scan the thread but couldn't see whether you have tried that.
Thanks for that......Working now :) woohoo.
But still getting a controller soon.
87%
