Now that the weekend is almost here, what is the official last update and are there going to be any more updates prior to next week? Would not want a surprise on Saturday. :)
geposted Thu 15 May 14 @ 1:36 pm
https://virtualdj.com/forums/187466/VirtualDJ_8_Pre-Release_Forum/Change_Log_and_Bug_Fixes_-_CURRENT_BUILD_1752.html
Updates to a Pre-Release software may be pushed at any time. BUT, they will not push whilst the software is open, they only display on launch.
If you have a concern you can turn off updates in the config menu. Or just use V7 for time being.
geposted Thu 15 May 14 @ 1:38 pm
Judging by the number of bugs reported, I'm pretty certain there will be new builds released over the next couple of days. Guess we will have to wait and see. I wouldn't recommend using VDJ 8 live at a gig yet though.
geposted Thu 15 May 14 @ 1:41 pm
Keep in mind its still recommended to use 7 and not the 8 pre-release for important events.
Well, despite the bug list, none of them impact me or any known work arounds are enough. I use a DAC-3. Don't do video at the moment. And use a simple USB 7.1 sound card.
So, I'll give 8 a whirl and if it does something stupid, I will have 7 at the ready. Gotta get used to it one way or another.
geposted Thu 15 May 14 @ 1:54 pm
I have not had any issues with using 8 so far, but the only thing keeping me from using it live is the missing midi clock. I need that to communicate with my lighting software.
geposted Thu 15 May 14 @ 3:25 pm
