I have a RMX 2 and the gain on each deck don't control the gain or move with the RMX 2,I map it 4x,but when I close VDJ-8 the gain stop working. I have a Mac
geposted Thu 15 May 14 @ 11:43 pm
Gains work fine here.
Could you please explain your situation a bit more in detail ?
when you move the Gain knobs of your RMX2, do you see the Gain sliders on the screen moving as well ?
Any chance you have custom definition in /VirtualDJ/Devices folder ? If yes, please try to remove it and relaunch , in order to apply the default one
geposted Fri 16 May 14 @ 12:26 am
The Gain knobs on the screen don't move with the RMX 2 on each deck with 2 players.
geposted Fri 16 May 14 @ 9:17 am
