iv think iv done ok... sliders move, knobs turn all works fine...
is all looking ok who knows anything bout djm 700 mapping
geposted Fri 16 May 14 @ 6:24 am
coz its a 4 ch mixer, am i meant to use a 4 ch skin?
geposted Fri 16 May 14 @ 6:42 am
What is it your trying to do exactly??
geposted Fri 16 May 14 @ 7:03 am
control eq's, master vol, gain and volume sliders.... not keen in using the cross fader, i never use the fadder, i always use the vol sliders
geposted Fri 16 May 14 @ 9:11 am
Being that it's an external mixer there's really no point in mapping the EQ's unless you use a fake command. If you don't you'll just be doubling up the eq, make sense? Same with the volume sliders. You could map those to fade the video though as the volume drops.
Other then that there's not much to map because it is an external mixer. You could also map the little crossfader reverse buttons as well.
I have an 800 an just did all this not to long ago.
geposted Fri 16 May 14 @ 9:48 am
Yeah, it boggles the hell out of my logical mind why people with hardware seem to think they need to use the "pretend" version on the screen!
geposted Fri 16 May 14 @ 10:41 am
I just want to use it for recording purpose via vdj... while doing gigs.
Gigs bring out the best in me when recording. ..
When home, I can hook up onto my pc
:D
:D
geposted Fri 16 May 14 @ 9:20 pm
I'm using the DJM-900. With VDJ7 it was simply plug and play. Does anyone know how to get it working with VDJ8 without having to re-map the whole entire unit?
geposted Tue 20 May 14 @ 4:12 pm
