Topic: Android remote...
What are the realistic chances of an Android remote being made for vdj8 please? It is after all the majority smart phone OS and would make this brilliant brilliant new version just perfect
geposted Fri 16 May 14 @ 6:42 am
Seconded !
You can already do it if you want.
TouchOSC=VDJ Remote
Paulm72 wrote :
Seconded !
This^^
TouchOSC=VDJ Remote
OSC was "barely compatible" with Version 7. I doubt it will be any better with v8. Can you verify the functionality with 8.0?
Currently I use splashtop but it's not ideal. Works well etc as a piece of software but a real remote control would be infinitely preferable.
I have no issues with Splashtop at all, although there are many different versions and it may depend on your individual setup. It works perfectly for me and unlike iremote you have full functionality including browser and search.
The current iremote is half baked and hasn't been touched in years.
Keith
The existing iOS could do with a bunch of bug fixes. I ran into a ton of problems that I had to work around when I created the Performance Pad skin.
TouchOSC=VDJ Remote
Barely compatible?? Phantomdj had everything mapped out! Only thing you couldn't do was see the track names or effect names but if you make your own template you could name the button for that effect if you want.
As for working with 8 I see ABSOLUTLY no reason why it wouldn't. It's all gonna boil down to how much work you wanna do and most folks here are straight lazy and want everything handed to them.
TouchOSC=VDJ Remote
For me it worked and was kinda hit an miss. I never wanted to chance it at a wedding (as an example) but used to occasionally for parties etc. What I found was the I would loose connection (could have been my phone tho) at least once a night and the only way to resolve the issue was to reboot. And when I switched off OSC I would loose complete control of my controller (vms4) thus I had to reboot. Maybe it was my configuration but it was never really stable for me.
anything new on this ?
virtual dj 8 remote required for android
