Hi, One thing that I've always thought needed changed is the size of the automix point I think it needs to be a bit bigger or have a tab attached to make it easier to click on without accidentally jumping to the end of the track thats playing
geposted Fri 16 May 14 @ 7:42 am
Can't you open the automix editor and just slide the track over? Haven't played with it much, so I'm not sure.
geposted Fri 16 May 14 @ 7:44 am
Yes but that is just way to many steps, when in v7 all you had to do was drag and your done. Also i do not use a mouse when I dj. In V8 you can just right click on the song and select mix now. Or even use one of the user custom buttons and make it a mix now button which is what i did.
Keep em dancing
Keep em dancing
geposted Sat 17 May 14 @ 12:37 pm
