I took a look at downloading some samples today. I got this message say that Security Setting has blocked this application.
Is there a way round this?
geposted Fri 16 May 14 @ 8:34 am
it's ok :))
geposted Fri 16 May 14 @ 8:36 am
how do i stop it from blocking the application?
geposted Sun 18 May 14 @ 4:11 am
if is your antivirus program you can add vdj as a exclusion.not sure if this is with windows defender or MS security essentials...if you can do the same..
geposted Tue 20 May 14 @ 8:44 pm
