I'm out working right now with background music on, as each new song in automix comes in the volume fluctuates for a second it goes up and down like as its trying to find it's correct level, V7 did not do this.
geposted Fri 16 May 14 @ 2:18 pm
Volumes are all over the place, it doesn't seem to autogain like it used to, so quite tracks now play quietly whereas before VDJ auto sorted the levels.
geposted Fri 16 May 14 @ 2:29 pm
did you play the songs in v7 with the auto+remember option...?
geposted Fri 16 May 14 @ 2:46 pm
As I say before in other topics autogain isn't working when automix is on!!!
geposted Sun 18 May 14 @ 1:50 pm
Indeed it is not working, a pain.
geposted Sun 18 May 14 @ 2:40 pm
What are your autoGain settings in options. I've been using automix here at my house for the last 4 days doing video and audio without issue.
Could it be that the limiter is kicking in on you also?
Two things that I have done are set my zeroDB to 0.8 and set autoGain to only auto.
geposted Sun 18 May 14 @ 6:16 pm
I've been having the same problem all week. I had a wedding last night and for the first half of the event it was doing it. I have a wedding tonight and tomorrow. I need a quick fix asap. I can't run the auto remember when I'm live mixing with a DDJ-SX controller. It constantly fights with my live mixing volume. But the volume issue just started last week. Virtual DJ guys, please resolve the issue asap.
geposted Fri 15 Apr 16 @ 6:41 pm
