Is there a way to map a button to only enable loop_back for a certain deck?
geposted Fri 16 May 14 @ 2:51 pm
have a look a the new custom buttons. They are assinged for each deck and you can set there a loop back command also
geposted Fri 16 May 14 @ 2:55 pm
I tried that before posting but it activates loop back on both decks.
geposted Fri 16 May 14 @ 3:27 pm
Loop back is a global mode, so you cant have it on/off to individual decks
geposted Fri 16 May 14 @ 8:50 pm
buenos dias alguien me puede colaborar en virtual dj 8 en grabacion.me dice configure el origen audio loopback y no me deja grabar les pido disculpas por las molestias gracias....
geposted Fri 12 Jan 18 @ 6:34 am
