Does anyone else have this? when i goto the config screen and want to change anything the tree expands and when i goto either scroll or do nothing it collapses on me. so this leaves me not able to change my setting accordingly
geposted Fri 16 May 14 @ 3:47 pm
Someone posted a video on you tube about this, so you are not alone .........
geposted Fri 16 May 14 @ 4:26 pm
ahhh gotcha
geposted Fri 16 May 14 @ 7:12 pm
So do we have an answer without going to youtube?
geposted Sat 17 May 14 @ 5:06 am
It is NOT a solution on YouTube, just a video showing what was happening !
geposted Sat 17 May 14 @ 5:53 pm
It happened to me also and it was due to me running visualizations, video, and other stuff at the same time as being in the menu system. It appears that VDJ gives priority to the music then the video/visualizations as far as memory usage is concerned. Meaning that if your system memory is close to full then VDJ will shut down what it needs to within the program so that the music continues to play smoothly. So; either use fewer VDJ resources (eg; settings, visualization, effects etc) or get a beefier computer.
I am not 100% sure I am correct with this hypothesis but it worked for me and it makes sense.
geposted Sat 17 May 14 @ 8:35 pm
YEah it happened for the first time to me as well, on my laptop. Nothing running. Just opened the program went right to config and every time i triedto change a setting it closed on me. I was in the config section two or three days ago with no problem.
geposted Sat 17 May 14 @ 10:56 pm
