Topic: Nudge option
Two things. If i remember correctly there was an option on the 7 to regulate the nudge function on the platters/jogwheels. The nudge on the controller is too fast. Second on my controller (mc6000) the sampler button allows me to move through the sampler options like audio fx and instruments (i like this feature) but whenever i press it i get a little skip in the music playing
geposted Fri 16 May 14 @ 7:09 pm
setting JogsensitivityBend will help you to find your proffered value.
When you choose to change Bank, the software loads ALL the samples from the Bank into memory, so either you have a bank with a large number of samples or the samples have large filesize, or if none of this is the case, then propably you need to make sure your computer is well optimized... https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
the thing is I'm using mac and vdj8. so for example for the nudge/bend settings i don't see that in the options for vdj8 and for optimising do you have anything for mac?
K i got the jog sensitivity bend. Had to click on advance options. I hadn't even noticed that before today
