System crash while playing an audio file and activating Sonique video effect - WZoomer (did all others in list without crashing so was right near the end). Had been activating all effects to see how it worked without crashing. Didn't manage screen grab before restarting.
geposted Sat 17 May 14 @ 10:26 am
but Sonique video effect is not compactible with V8
geposted Sat 17 May 14 @ 11:47 am
Sonique is compatible.
There is no longer a plugin requirement. They run natively.
Just select your sonique visual and it will load.
geposted Sat 17 May 14 @ 11:49 am
Thank you for the information
geposted Sat 17 May 14 @ 11:53 am
Yep - all was working fine, did wonder if it had just had enough by the time I got to the end!
geposted Sat 17 May 14 @ 12:18 pm
