With the + button it should cycle.... small, large but bottom banner showing, fullscreen.
I had VDJ on small screen and moved most of this below the task bar with the top inch or so above the task bar and was working on the extended desktop, went to maximise this screen witch worked then switched to
minimize and only got the portion of screen that was above the task bar!
Ive ended VDJ and started it back up, still not right, restarted the computer still not right .... looks like uninstall and reinstall VDJ!!!
Using Acer Aspire V5 571PG
Intel I7 1.9 (2.4) CPU
8GB RAM
INTEL 4000 (internal)
NVIDIA Geforce GT 620M + 1GB (using Optimus) VDJ Set to Use this GPU
VDJ 8.0.1765.644
Windows V8 64
Sorry mis-spelling in title
8GB RAM
VDJ 8.0.1765.644
Windows V8 64
geposted Sat 17 May 14 @ 10:27 pm
