Previewplayer don´t play Sampler. If i turn it on and change to the other Samplers Previewplayer crashed
Sampler are 0:05 mp3
geposted Sun 18 May 14 @ 12:22 pm
Check your audio config's sound card. For example:ASIO Buffer
.gif)
geposted Sun 18 May 14 @ 12:57 pm
Why are you posting these pictures everywhere??
geposted Sun 18 May 14 @ 1:19 pm
I can play 8 Sampler and then it stop´s playing
ASIO Buffer is on 12-32 its change nothing
geposted Sun 18 May 14 @ 1:32 pm
It works OK for me.
What format are your samples?
16 bit/24 bit/44.1khz/WAV/MP3?
geposted Sun 18 May 14 @ 1:44 pm
i have mp3 wav and vdj
mono 8000hz 32bit
stereo 22050 32 bit
mono 22050
stereo 44100 32bit
everyone sampler is different maybe thats the problem
mono 8000hz 32bit
stereo 22050 32 bit
mono 22050
stereo 44100 32bit
geposted Sun 18 May 14 @ 2:03 pm
