Hi everybody,
Impossible for me to use DENON SC3900 in hybrid mode.
Problems : when i play a track, then sound "freeze" every 2 or 3 seconds
What is the right config to use it ?
I'm on Mac, with a SL3 Soundcard.
Thanks
Thanks
geposted Sun 18 May 14 @ 1:34 pm
did you find a fix? I can not get mine to work at all
geposted Fri 30 May 14 @ 10:41 pm
You're a moderator, you have more inside info than us?
http://www.virtualdj.com/forums/187139/VirtualDJ_8_bug-report_Forum/Denon_3700s_x1600_issues.html?search=denon%203700&page=1
3900 talk in there as well.
geposted Fri 30 May 14 @ 11:54 pm
If you set the MIDI mapping to ignore in v8 does the problem go away for you?
I'm not saying this is the fix BTW, just a test :)
geposted Sat 31 May 14 @ 4:09 am
Could you please try to test again with the latest build and report back of any issues left ?
thank you
thank you
geposted Tue 23 Sep 14 @ 12:41 pm
