For some reason beatlock sometimes turns itself on without being prompted, how do i turn this off on the original version 8 skin? i can't seem to find the option anywhere
geposted Sun 18 May 14 @ 2:53 pm
You can use a custom button
beatlock
beatlock
geposted Sun 18 May 14 @ 3:07 pm
Tried that, it stays stuck on. I've also found the original beatlock button on the scratch waveform panel but it's not turned on and both deck tempo faders still move together.
Really can't work out why it's doing it, there's no controller attached either.
geposted Sun 18 May 14 @ 3:21 pm
maybe pitchlock is enabled then.
Action : pitch_lock
try that with a custom button.
Action : pitch_lock
geposted Sun 18 May 14 @ 3:24 pm
Cheers DJDad that's done the trick for now, think I was getting confused between beat-lock and pitch-lock. I'm still not sure why it's been turning itself on at random points.
geposted Sun 18 May 14 @ 3:41 pm
