in V7 there was an option to disable Video Completly.
is there an option to do the same with V8 (don't use video and it themes that the probs V8 has are relayted to Graphiccard/Video)
geposted Mon 19 May 14 @ 5:23 am
If it behaves like in v7, then deactivate "show video files" in the browser.
geposted Mon 19 May 14 @ 5:30 am
did this mean video functions are disabled (no code in backround) or only don't show the video files?
in v7 i can play the audio stream of an video but video functions are disabled
geposted Mon 19 May 14 @ 6:03 am
means "do not show up videofiles in the browser"
function you are looking for:
set "startVideoOnLoad" to "no"
geposted Mon 19 May 14 @ 6:20 am
thanks that help
thought that this key did something else because if go to a video file and play it it works even if i say no with that key
geposted Mon 19 May 14 @ 8:14 am
