VirtualDJ 8 - Controller by DennYo
This is my first V8 Skin and based of my V7 Controller Skin.
Features:
-new look
-include V8 features (for example: sandbox, Horizontal Scratch Wave, Loop Save/Load, etc.)
Screenshots:
____________________________________________________________________________________________________
Best Regands
DennYo aka Denny F.
Features:
-new look
Screenshots:
Best Regands
DennYo aka Denny F.
geposted Mon 19 May 14 @ 1:48 pm
Skin is available
http://www.virtualdj.com/addons/16727/VirtualDJ_8__-_Controller_by_DennYo.html
Just a side note. You d better avoid adding Sandbox in skins that don't offer any mixer elements. Reason is that when Sandbox is enabled you can use of course any part of the mixer on your controller and try how the next song probably mix with the one you have on the other deck, BUT when Sandbox is disabled again, you need the ghost faders on the skin to know where the software sliders are and where to you need to move the sliders of your controller in order to regain control.
And of course for those who need to use this skin for external mixer setups, keep in mind that Sandbox only works for Master/Headphones audio setups
Bug. It seems that the LOAD/SAVE buttons only work as menu and not as actions, unless i am wrong
Possible bug. BPM is displayed twice inside the Deck Info and both show the same value. Not sure what is the purpose of this.
Cosmetic bug. the Gain knob of deck 2 has the graphics of deck 1
Tip1 . Try to use Serato less. It has somehow possessed you and your skin looks like that a lot ;)
Tip2. Have the songpos shorter, get rid of the Sandbox (or provide an option to hide it) and have the Browser larger
Tip3. Better choose making skins using deck left deck right instead of deck 1 and 2. This way, you could even use the skin with 4 decks and controllers that can swap between them ;)
geposted Mon 19 May 14 @ 3:53 pm
Thanks for the good ideas in the German Forum.
Thanks for your statement djdad.
Update 2.0
-Sandbox is unvisible when not in use (Sandboxbutton on top)
-Change between 3 different wave sizes
-Change deck color (blue/red - yellow/red - blue/yellow)
-Change the remain time in the platter
-Toogle between the vertical Scratchwave or a Pitchfader
-Add a prelisten player in bottom of the Browser like VDJ7
-little Bug fixes
Best regards DennYo
Update 2.0
-little Bug fixes
Best regards DennYo
geposted Sun 25 May 14 @ 6:15 pm
Update 2.2
Update 2.2
-Add Custom Browser Icons
Update 2.1
-Bugfix Waveform Color
-Songposwave smaller for better optik
Best Regards
Update 2.2
Update 2.1
Best Regards
geposted Sat 14 Jun 14 @ 6:59 am
Update 2.3
-Add white Skin for sunny days
Best Regards
Best Regards
geposted Sat 14 Jun 14 @ 10:54 am
Update 2.4
-Change Deck 1 to Deck left & Deck 2 to Deck right (Information Swap but not color swap. That comes later)
Best Regards
Best Regards
geposted Sat 14 Jun 14 @ 1:24 pm
Update 2.0
-little Bug fixes
Best regards DennYo
Update 2.0
-little Bug fixes
Best regards DennYo
How about an option to remove the scratch wave between browser and decks
geposted Sun 15 Jun 14 @ 9:12 am
Good idea. Too much waveform stuff going on for my tastes. :-)
geposted Sun 15 Jun 14 @ 11:49 am
great skin,one of the best, in my opinion, Combat Skin is also very nice, but the scratchwaves are too small,this size is perfect for scratching, will DennYo update this skin for using 4 decks?
looking forward
thank you
looking forward
thank you
geposted Fri 20 Jun 14 @ 4:00 pm
Update 2.0
-little Bug fixes
Best regards DennYo
Update 2.0
-little Bug fixes
Best regards DennYo
hey Djratedxxx919 i was gonna ask the same thing. i love this skin but me personally i wish the browser area was bigger and get rid of and or hide them big azz wave forms :-)
geposted Sat 21 Jun 14 @ 3:56 am
please DennYo do NOT remove the scratchwaves,if so make it an option on the "wave" button on-screen, the scratchwaves are the best feature on the skin,in fact it is the the only skin available with big wide color waves, I would like to request an update to a 4 deck skin, with scratchwaves,
looking forward
thank you
(I found that assigning deck left/right I can switch view the scratchwaves of the 4 decks,2 at a time)
looking forward
thank you
geposted Sun 22 Jun 14 @ 8:05 pm
i will create a update for hide the waveform :)
But now i build a 4 deck variation.
first look
first look
geposted Sun 22 Jun 14 @ 8:14 pm
looks good, I think you could just mirror the skin, and have the 4scratch waves in the middle, or we could switch between advanced decks with the bigger rotating jogwheel, or the smaller decks with no jogwheel,showed on the preview by DennYo.(take a look in Combat Skin)
IMO I would like to have the mirrored DennYo 4 decks full view with 4 scratchwaves in the middle,and the browser could be smaller...
looking forward
thank you
looking forward
thank you
geposted Mon 23 Jun 14 @ 9:00 am
Update 2.6
-Add a 4 Deck Version
-some Bugs removed in the 2 Deck Skins
geposted Mon 23 Jun 14 @ 11:33 am
first look
first look
+1 i live your skin the most out of all the ones ive downloaded so far (BUT) the big wave forms is taking up to much browser space for me. yes i know i can click on browser but i like the top area of your skin. cant wait till the update. im an old school DJ (mixx by ear) i never need nor look at wave forms ;-)
geposted Mon 23 Jun 14 @ 12:30 pm
I have a big list with new ideas and I create an new version 3.0 in this version you can disable the waves :)
geposted Mon 23 Jun 14 @ 1:48 pm
djtyme209 wrote :
+1 i like your skin the most out of all the ones ive downloaded so far (BUT) the big wave forms is taking up to much browser space for me. yes i know i can click on browser but i like the top area of your skin. cant wait till the update. im an old school DJ (mixx by ear) i never need nor look at wave forms ;-)
first look
first look
geposted Mon 23 Jun 14 @ 3:25 pm
Update 2.7
-Bugfix VU-Meter & Gainslider Deck 4 (Pitchfader swap) wrong color
-Bugfix Dropzone Deck 2&4
________________________________________________________________________________________________________
Update 2.8
-Bugfix Scratchwave always visible
Update 2.8
geposted Tue 24 Jun 14 @ 8:00 am
Link for download free??
geposted Tue 24 Jun 14 @ 8:28 pm
The Link is for PRO Infinity Users free.
geposted Tue 24 Jun 14 @ 8:34 pm
