is there any logic in the code that does a timeout if the file its looking for no longer exists on the Netsearch or ContentUnlimited servers?
so my scenario is, I selected 30 virtual files to download to cache, it did 15, then the 16th one it just seemed to stop, it could not find it, so it didn't continue on, I had to cancel that one so it would move on to finish the rest.
Thanks
Thanks
geposted Mon 19 May 14 @ 2:02 pm
          so whats this?  and is there a key command on the Mac i can use to stop or break a download as this one looks stuck.  i have to Force Close VDJ8
       geposted Mon 19 May 14 @ 7:46 pm
          Yes we have a bug in the latest build for the Content Unlimited files. For now, please download to cache the files you need instead of loading/streaming. Will be fixed soon.
    geposted Mon 19 May 14 @ 7:54 pm
