A couple plugins are incompatible and do not carry over to VDJ8 so when im using my controller to change a FX on one of my touch pads and it scrolls through the incompatible plugin , it stops my software until I click ok on a pop up window. So those who have incompatible plugins be sure to check which are incompatible and remove them from your folder.
geposted Mon 19 May 14 @ 5:30 pm
in later updates they should no longer be shown inside vdj 8, if you see any that dont work, report ;)
geposted Mon 19 May 14 @ 5:34 pm
