Hi all...this may be because it's the pre-release...but I sure miss being able to assign a video effect for audio files only. I used slideshow with club flyers it worked out great when i wasn't using video. Any way to bring that feature up in VDJ 8?
    geposted Mon 19 May 14 @ 7:27 pm
          config -> options -> advanced
videoAudioOnlyVisualisation
geposted Mon 19 May 14 @ 8:02 pm
          Hi;
I need some assistance with Music Video and Audio Visualizations as well. When I play Music Videos they work as they shouls but in order to play an Audio Track with a Visualization it has to be selected manually on the Video Mixer using the effect button even though it is set in Config. It dosen't seem to matter if i am going from deck to dck using A & B or if I use AUTOMIX. Also if I am running a Music Video and select the Visualization it will take over the main window or screen.
I have gone through the manual but have found not answers.
Any Assistance is appreciated.
geposted Wed 21 May 14 @ 11:21 am
          Did you try the above?
    geposted Wed 21 May 14 @ 11:22 am
          Yes i did.
    geposted Wed 21 May 14 @ 11:36 am
          You must must have something set wrong.
You do not need anything set in the Master_effect dropdown box.
Just the videoAudioOnlyVisulaisation
geposted Wed 21 May 14 @ 11:50 am
          I'll take a look at the config.
    geposted Wed 21 May 14 @ 11:53 am
          Can the Master_Effect be cleared?
    geposted Wed 21 May 14 @ 11:57 am
          You don't need to clear it, just make sure nothing is switched on.
    geposted Wed 21 May 14 @ 11:58 am
          Okay, i'll take another look.
    geposted Wed 21 May 14 @ 12:07 pm
          Got it, it is working as it was in 7.4... THANK YOU!
    geposted Wed 21 May 14 @ 12:12 pm
          No problem
    geposted Wed 21 May 14 @ 12:19 pm
          Yeah....I kinda feel like a fool on this one. I caught on shortly After I made the Post...SMH
    geposted Wed 21 May 14 @ 7:58 pm
          I saw this and it has a few great reviews on the VDJ8 and one was on this visualisation... not a bad review
http://youtu.be/s6NZ-iQwcZo
geposted Wed 21 May 14 @ 11:27 pm
