Guys, how can i repoint VDJ8 to use my external drive for the cache folder? I want to copy the entire cache folder to my external drive and point the software there...I remember in VDJ7 there was a database setting to point it there then I would update the XML file with the new location on all references to my old location, is that doable in VDJ8? thanks
geposted Mon 19 May 14 @ 11:45 pm
No, the Cache folder could not be changed in version 7 and cannot be changed in version 8 either.
what you can do of course, is use File Operations within VirtuaLDj to move your cached songs to a new folder (in any Drive), and then create a Filter Folder to gather all vdjcache files to refresh DRM authorization easier
geposted Mon 19 May 14 @ 11:49 pm
so going forward I will have to keep copying any newly downloaded to cache files over to my external drive? no way to force it there?
geposted Tue 20 May 14 @ 10:22 am
Yes. I have a filter folder set up on my machine to see which cache files are sat on the wrong drive:
File Type contains 'vdjcache' & drive is 'c'
geposted Tue 20 May 14 @ 10:58 am
