Topic: Bugs and annoyances
1. When losing a video, the screen will now flash black or restart the program. If it just flashes black the browser and folders will be reset to as if you just entered the program. If it restarts you will get no sound after it restarts. only way to fix is by exiting the program again and restarting
2. minor annoyance, folders will show a "+" sign next to a folder that doesn't have anything to expand this happens to both main folders and sub folders.
3. When Music videos finish playing the window doesn't close, even if you try to close it manually. the window stay black. even if you minimize the program. only way to fix this is to exit the program.
4. While searching for Content Unlimited tracks, VDJ8 can restart but reloads tracks and continues to play , there is silence for a moment.
geposted Tue 20 May 14 @ 12:06 am
