hello , can u fix or i get browser sort same vdj 7
in vdj 7 the sort is great
like when i sort the key or harmonic with bpm ?
geposted Tue 20 May 14 @ 10:04 am
please check change.log from the latest build....
there was a fix in the browser sort...but not shure if the fix solved what you´re asked for...
geposted Tue 20 May 14 @ 10:10 am
seems to work ok here - first i sorted the keycode, then the bpm, and it keeps the keycode sort
geposted Tue 20 May 14 @ 10:19 am
Great....many User asked for that....
another good job guys...!!!
geposted Tue 20 May 14 @ 10:22 am
Um? You can't tell if it keeps the order if every song of your screenshot has the same BPM, Key and Harmonic Key...
geposted Tue 20 May 14 @ 10:33 am
Doesn't work here.
I select Harmonic and it sorts by harmonic, but as soon as I sort by BPM, the harmonic list is random.
geposted Tue 20 May 14 @ 10:51 am
Agreed, doesn't work for me either.
geposted Tue 20 May 14 @ 10:54 am
sorry ...did not testet it before...but did right now...
does not seem to work...
geposted Tue 20 May 14 @ 10:59 am
Same problem here... It's important for DJs that "mix in key" to have sorted the list first in Key and then in BPM
geposted Wed 21 May 14 @ 2:48 pm
Create a Filter Folder: group by key or group by harmonic
When you select the Filter Folder you could sort by a second value.
Greets, Heiko
Greets, Heiko
geposted Wed 21 May 14 @ 2:58 pm
Is that the only way to do it now? No fix planned for the browser?
geposted Wed 21 May 14 @ 2:59 pm
Will probably get a fix.. if its not working..
geposted Wed 21 May 14 @ 3:05 pm
May we also have a search option added for Harmonic Key ? Currently its only Key.
Cheers
Cheers
geposted Sat 07 Jun 14 @ 3:04 pm
Same problem - in 7 you could click to sort by BPM, then click to sort by Key and it would have what is displayed in the photo above where all the keys are in order by BMP. Not sure any of these recommendations are making a ton of sense to me... Any help?
Thanks!
Thanks!
geposted Mon 09 Jun 14 @ 3:20 pm
Is there a way in 8 to have it sort like 7.4.1 did where it first sorted I believe by play count (though you didn't necessarily see that column) and then everything else that may not have been played was sorted by Artist. I guess a double sort - Play Count, Artist?? I tried typing that in in the Browser settings but it only sorted by whatever was first. (browserSort - file=Play Count, Artist)
geposted Mon 09 Jun 14 @ 4:55 pm
I think I posted about this weeks ago too. https://virtualdj.com/forums/188473/VirtualDJ_8_Pro-Users_Forum/Filter_Folder_Help_-_Different_Sorting_Options.html?page=1
I too have the problem where if I select say "Artist" as the sort option that applies to everything even filter folders. So when I click on "Most Played" it doesn't sort by play count but rather artist.
In v7.4.1 this all worked fine for me. Is this now by design in v8 or a bug?
geposted Tue 10 Jun 14 @ 1:55 am
My guess is it's more likely to be 'we forgot to add it when making our development schedule' ;)
geposted Wed 11 Jun 14 @ 10:35 am
So what's the score on this? I need to sort by artists and key (coz I sometimes forget if I already played a track if it's a different mix. Especially if it's a new track I am not so familiar with). Yeah I know. Lame but that's just how I am. :P
geposted Sat 05 Jul 14 @ 7:44 am
