Forum: Old versions
Topic: Playlists and Side List
Hi,
Wonder if you could shed some light on what I am doing wrong! :-(
If I choose to load my saved playlist into the side list instead of automix, when I delete them tracks from the sidelist it deletes from the playlist. What is causing this to happen is this correct or a bug. Just wondering really. Great update to the software, thanks atomix.
Daz
geposted Tue 20 May 14 @ 11:31 am
Makes sense to me (Mr Logical).
If you load your playlist onto the sidelist, then playlist = your sidelist and sidelist = playlist.
Therefore if you delete something from your sidelist, you're deleting it from your playlist.
Thanks for the quick response!
So if the playlist is the sidelist then what is the point of having the sidelist or the playlist why not just have one or the other??
I know ... I'm being thick .....
Second question as well if you can help ... Where do loaded but not played songs goto?
They're two different things (at least that's the intended purpose).
The sidelist is kind of a storage area for tracks that you might play.
The playlist is usually what you'd load for use with automix - and indeed in VDJ 8 there is no playlist. It's now just called automix.
That was confusing but I think I got it lol.
Having trouble with playlists I place all the tracks I want in the Center window then drag them into a new playlist once in there all seems fine. Now when I return to this playlist later on the order has now changed. If I thrn reposition the tracks again there is no option to save the playlist as there was before what am I doing wrong
right click the column header and click reset order and it should be the way you created it
+1
It took me a while to figure that out. I can now take an old set list and sort it to find something I need and then to reset the sort order to bring it back to how I played them.
joe...
I have 2 questions:
1) how do you change the digital clock at the top of VDJ 7 pro so it reads the correct time
2) Having just installed VDJ 7 and after loading my tracks into the centre browserI wanted to make up some playlists. so dragged the tunes over but only managed to get 30 mins worth. When Ive used the playlist on a friends before, I can load an unlimited amount of tracks. How do i get the unlimited amount of tracks into the playlist?
jeffnation wrote :
I have 2 questions:
I reads your computer time. Clicking on it will change its layout differently depending on the skin.
I am not aware of there being a time limit. I have several hours in a few lists and did not change any setting.
