OK ihave my Voxoa M70 setup with VDJ for home use But i wanna setup my VCI400 for mobile use but its not letting me change any thing it just keeps reverting back to my M70 settings...
    geposted Tue 20 May 14 @ 7:17 pm
          Salutations Everyone,
I'm feeling VJ8 and so far so good, haven't started recording any sessions yet to know how good. I use a set of Dicers with a N4 and notice a slight lag in the Dicers when Hot Cueing from them but not on the N4. I looked in the setting to try and find any Latency controls for any of the Midi devices and had no luck. Is there something I'm missing.
Much appreciated and Thanks in Advance.
geposted Tue 20 May 14 @ 7:33 pm
          ok need a mapping...on my VCI400 theres a cue button next to the play button i want this behavior if no cue set return to beginning of song, if a cue 1 is set it goes to cue 1 and have a stutter behavior.
    geposted Tue 20 May 14 @ 8:22 pm
          okay trying to remap my VCI-400 so in the changes in V8 for example i could map my sync button to blink like the beat grid with this
Map the LED of the SYNC button as ..
get beatpos & param_mod 1.0 & param_smaller 0.25 ? on : off
why woldnt it work in version 8
geposted Tue 20 May 14 @ 11:10 pm
          Does this do what you want?
get_beatgrid 100%
    get_beatgrid 100%
geposted Wed 21 May 14 @ 10:58 am
