Here is a particular video that is not loading fully into vdj8 that loads fine in 7. Memory limit? Im rolling with a 2gb dedicated video card, 16 gigs ram... mega Asus gaming laptop
geposted Tue 20 May 14 @ 11:58 pm
Please change at OPTION -> AUTOCUE to CUE or SKIP SILENCE
If this will solve the issue i can tell you it is reported and should be fixed soon.
geposted Wed 21 May 14 @ 1:51 am
I did have it set to Autocue>Cue and switched it to Skip silence per your suggestion.... kind of fixes it... it at least is playable. However, the track loads in half the waveform area.
geposted Thu 22 May 14 @ 1:36 pm
