I have now downloaded virtual dj 8 and working my way round it and it's great I have just one problem and that is when I go onto my karaoke external hard drive and open it it shows the files in there but not in zip files and they don't open as though there is nothing in there they are all in my database and when I type a song title in or the artist they are all in there and they play okay with no problems I have put gone back onto virtual dj 7 pro and all is fine in there and all in zip files
geposted Wed 21 May 14 @ 1:21 pm
There is a config option - showzipkaraoke - which you need to enable.
geposted Wed 21 May 14 @ 1:34 pm
Just done that and it works fine thank you very know very happy thank you
geposted Wed 21 May 14 @ 2:00 pm
where can i find the config option?
geposted Sun 01 Jun 14 @ 7:42 pm
You need to enable advanced options in upper right corner:
geposted Sun 01 Jun 14 @ 7:45 pm
Thank you so much. just needed to click advanced options
geposted Sun 01 Jun 14 @ 7:50 pm
