Topic: VDJ8 bugs found so far
System: MBP running 10.7 with 8gb ram intel i5 2.4Gz.
When Playing tracks in automix the fade in is not clean, it seems to clip-out rather then blend into the track default was set to 4.00 seconds I changed to 6.00sec to see if it helped and it persisted. (by clip-out I mean the track is heard poping in and out)
Adjusting settings in the config while tracks are playing causes the track to skip and it can be reproduced consistently by pressing apply without closing the config window.
crash of application when wave form zoom is modified when in scratch mode on mixer panel and config is selected at any time after the modification of waveform(message below):
../src/propgrid/propgridpagestate.cpp(1693): assert "Assert failure" failed in PrepareToAddItem(): wxPropertyGrid item with name "rhythmZoom" already exists
Call stack:
[00] 0x0000000108121a23
[01] 0x0000000107db416d
[02] 0x0000000107db7993
[03] 0x000000010821c73c
[04] 0x000000010821c49b
[05] 0x000000010821c3ae
[06] 0x0000000107e8b830
[07] 0x0000000107e8c0f6
[08] 0x000000010821b164
[09] 0x000000010821c4ba
[10] 0x000000010821c3ae
[11] 0x000000010821c7cf
[12] 0x0000000107fe94f4
[13] 0x0000000107fe5622
[14] -[NSWindow sendEvent:]
[15] 0x0000000107fd5095
[16] -[NSApplication sendEvent:]
[17] 0x0000000107f55a38
[18] -[NSApplication run]
[19] 0x0000000107fcb6d4
[20] 0x00000001081fcc54
Do you want to stop the program?
You can also choose [Cancel] to suppress further warnings.
geposted Wed 21 May 14 @ 9:25 pm
Please try to change the setting 'crashGuard' (in Advanced Options) to No, relaunch Virtualdj and try to reproduce the crash. This time, a Mac crash report will be generated and post the content of that report here.
*update*
1. Automix fade issue resolved: Changed the curve in the config to smooth from full.
2. Adding tracks to automix while music is playing causes a clip in the song
3. Waveform saving in scratch mode: I have changed the crashguard to the suggested setting and the error still appears. What report level should it be set to? (currently set at 0 by default) Wherewill the mac dump be written?
Call stack:
[00] 0x000000010bc20a23
[01] 0x000000010b8b316d
[02] 0x000000010b8b6993
[03] 0x000000010bd1b73c
[04] 0x000000010bd1b49b
[05] 0x000000010bd1b3ae
[06] 0x000000010b98a830
[07] 0x000000010b98b0f6
[08] 0x000000010bd1a164
[09] 0x000000010bd1b4ba
[10] 0x000000010bd1b3ae
[11] 0x000000010bd1b7cf
[12] 0x000000010bae84f4
[13] 0x000000010bae4622
[15] 0x000000010bad4095
[17] 0x000000010ba54a38
[19] 0x000000010baca6d4
[20] 0x000000010bcfbc54
vdj 8 Crash:
Process: VirtualDJ [1269]
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: 8.0.0 (8.0.1785)
Code Type: X86-64 (Native)
Parent Process: launchd [261]
Date/Time: 2014-05-25 15:35:15.317 -0400
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 11810498 sec
Crashes Since Last Report: 6
Per-App Interval Since Last Report: 74181 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 72665262-1EEC-4FFF-ADFA-EDAD299641E5
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGTRAP)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
objc[1269]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff879fd82a __kill + 10
1 com.atomixproductions.virtualdj 0x000000010b127fbb 0x10ad32000 + 4153275
2 com.atomixproductions.virtualdj 0x000000010b281a78 0x10ad32000 + 5569144
3 com.atomixproductions.virtualdj 0x000000010b2816c6 0x10ad32000 + 5568198
4 com.atomixproductions.virtualdj 0x000000010b282384 0x10ad32000 + 5571460
5 com.atomixproductions.virtualdj 0x000000010b27fcf0 0x10ad32000 + 5561584
6 com.atomixproductions.virtualdj 0x000000010b0a59c4 0x10ad32000 + 3619268
7 com.atomixproductions.virtualdj 0x000000010add40ab 0x10ad32000 + 663723
8 com.atomixproductions.virtualdj 0x000000010ae2ae18 0x10ad32000 + 1019416
9 com.atomixproductions.virtualdj 0x000000010aee6319 0x10ad32000 + 1786649
10 com.atomixproductions.virtualdj 0x000000010aee58e6 0x10ad32000 + 1784038
11 com.atomixproductions.virtualdj 0x000000010ae94779 0x10ad32000 + 1451897
12 com.atomixproductions.virtualdj 0x000000010b35573c 0x10ad32000 + 6436668
13 com.atomixproductions.virtualdj 0x000000010b35549b 0x10ad32000 + 6435995
14 com.atomixproductions.virtualdj 0x000000010b3553ae 0x10ad32000 + 6435758
15 com.atomixproductions.virtualdj 0x000000010b1f09e4 0x10ad32000 + 4975076
16 com.atomixproductions.virtualdj 0x000000010b355431 0x10ad32000 + 6435889
17 com.atomixproductions.virtualdj 0x000000010b3557cf 0x10ad32000 + 6436815
18 com.atomixproductions.virtualdj 0x000000010b1ac5b0 0x10ad32000 + 4695472
19 com.atomixproductions.virtualdj 0x000000010b0b6e52 0x10ad32000 + 3690066
20 com.apple.CoreFoundation 0x00007fff8b2cd70d -[NSObject performSelector:withObject:] + 61
21 com.apple.AppKit 0x00007fff831918ca -[NSApplication sendAction:to:from:] + 139
22 com.apple.AppKit 0x00007fff8327e7ff -[NSMenuItem _corePerformAction] + 399
23 com.apple.AppKit 0x00007fff8327e536 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 125
24 com.apple.AppKit 0x00007fff8351db08 -[NSMenu _internalPerformActionForItemAtIndex:] + 38
25 com.apple.AppKit 0x00007fff833ac6f9 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 138
26 com.apple.AppKit 0x00007fff831f89bb NSSLMMenuEventHandler + 339
27 com.apple.HIToolbox 0x00007fff8558f234 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1263
28 com.apple.HIToolbox 0x00007fff8558e840 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 446
29 com.apple.HIToolbox 0x00007fff855a56db SendEventToEventTarget + 76
30 com.apple.HIToolbox 0x00007fff855eb7b5 _ZL18SendHICommandEventjPK9HICommandjjhPKvP20OpaqueEventTargetRefS5_PP14OpaqueEventRef + 398
31 com.apple.HIToolbox 0x00007fff856d2e2d SendMenuCommandWithContextAndModifiers + 56
32 com.apple.HIToolbox 0x00007fff8571a5b5 SendMenuItemSelectedEvent + 253
33 com.apple.HIToolbox 0x00007fff855e4883 _ZL19FinishMenuSelectionP13SelectionDataP10MenuResultS2_ + 101
34 com.apple.HIToolbox 0x00007fff855dbfc9 _ZL14MenuSelectCoreP8MenuData5PointdjPP13OpaqueMenuRefPt + 600
35 com.apple.HIToolbox 0x00007fff855db592 _HandleMenuSelection2 + 580
36 com.apple.AppKit 0x00007fff830f91da _NSHandleCarbonMenuEvent + 250
37 com.apple.AppKit 0x00007fff8308ecc9 _DPSNextEvent + 2019
38 com.apple.AppKit 0x00007fff8308e07d -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
39 com.atomixproductions.virtualdj 0x000000010b104611 0x10ad32000 + 4007441
40 com.atomixproductions.virtualdj 0x000000010b3359c6 0x10ad32000 + 6306246
41 com.atomixproductions.virtualdj 0x000000010b335b82 0x10ad32000 + 6306690
42 com.atomixproductions.virtualdj 0x000000010b104be1 0x10ad32000 + 4008929
43 com.atomixproductions.virtualdj 0x000000010b335c54 0x10ad32000 + 6306900
44 com.atomixproductions.virtualdj 0x000000010b2b2a95 0x10ad32000 + 5769877
45 com.atomixproductions.virtualdj 0x000000010b092514 0x10ad32000 + 3540244
46 com.atomixproductions.virtualdj 0x000000010ade6d76 0x10ad32000 + 740726
47 com.atomixproductions.virtualdj 0x000000010ae94a9a 0x10ad32000 + 1452698
48 com.atomixproductions.virtualdj 0x000000010ae17911 0x10ad32000 + 940305
49 com.atomixproductions.virtualdj 0x000000010b08ed6e 0x10ad32000 + 3525998
50 com.atomixproductions.virtualdj 0x000000010b2e12bf 0x10ad32000 + 5960383
51 com.atomixproductions.virtualdj 0x000000010ae1780e 0x10ad32000 + 940046
52 com.atomixproductions.virtualdj 0x000000010ad33b84 0x10ad32000 + 7044
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff879fe7e6 kevent + 10
1 libdispatch.dylib 0x00007fff84502786 _dispatch_mgr_invoke + 923
2 libdispatch.dylib 0x00007fff84501316 _dispatch_mgr_thread + 54
Thread 2:
0 libsystem_kernel.dylib 0x00007fff879fe192 __workq_kernreturn + 10
1 libsystem_c.dylib 0x00007fff8a72b594 _pthread_wqthread + 758
2 libsystem_c.dylib 0x00007fff8a72cb85 start_wqthread + 13
Thread 3:: com.apple.appkit-heartbeat
0 libsystem_kernel.dylib 0x00007fff879fde42 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff8a6dfdea nanosleep + 164
2 libsystem_c.dylib 0x00007fff8a6dfbb5 usleep + 53
3 com.apple.AppKit 0x00007fff832c311b -[NSUIHeartBeat _heartBeatThread:] + 1727
4 com.apple.Foundation 0x00007fff89a8c72a -[NSThread main] + 68
5 com.apple.Foundation 0x00007fff89a8c6a2 __NSThread__main__ + 1575
6 libsystem_c.dylib 0x00007fff8a7298bf _pthread_start + 335
7 libsystem_c.dylib 0x00007fff8a72cb75 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000002 rcx: 0x00007fff6a929aa8 rdx: 0x0000000000000000
rdi: 0x00000000000004f5 rsi: 0x0000000000000005 rbp: 0x00007fff6a929b40 rsp: 0x00007fff6a929aa8
r8: 0x0000000000000004 r9: 0x00007ffdec649170 r10: 0x00000000000fbd40 r11: 0xffffff80002dad60
r12: 0x00000000000005dd r13: 0x00007fff6a929cd0 r14: 0x00007fff6a929c30 r15: 0x000000010c47e680
rip: 0x00007fff879fd82a rfl: 0x0000000000000202 cr2: 0x00007fff6a96732c
Logical CPU: 0
Binary Images:
0x10ad32000 - 0x10c307fa7 +com.atomixproductions.virtualdj (8.0.0 - 8.0.1785) <AA96117D-B3F2-3666-AB46-096079DB9F2D> /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
0x10cb59000 - 0x10cbaaff7 com.apple.audio.midi.CoreMIDI (1.8 - 42) <10BAC42F-ACFE-3EBC-869A-2847A0770CE8> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10df6c000 - 0x10df76fef libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <4572AD1E-D1D1-3412-AFCC-D37037B1FAB5> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
0x10df7c000 - 0x10df7fff7 libCoreFSCache.dylib (??? - ???) <0D155750-7910-32C5-8327-924FC1089442> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x10df87000 - 0x10df87ff3 +cl_kernels (??? - ???) <823460DE-EC2A-4F04-9254-3C0DE2F2593E> cl_kernels
0x11116e000 - 0x11120dff7 unorm8_bgra.dylib (2.0.19 - compatibility 1.0.0) <47DA7D73-C52D-322F-A08F-4DB320A65373> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff6a932000 - 0x7fff6a966baf dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
0x7fff83059000 - 0x7fff8307dfff com.apple.RemoteViewServices (1.5 - 44.2) <A0417D7F-22E9-3FD8-AC55-67654D8E93EB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff83086000 - 0x7fff83c8cfff com.apple.AppKit (6.7.5 - 1138.51) <44417D02-6123-3FC3-A119-CE51BB4C3006> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff83c8d000 - 0x7fff83c8efff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
0x7fff83c8f000 - 0x7fff83da8fff com.apple.DesktopServices (1.6.5 - 1.6.5) <5E7DD5F4-B4DA-3F75-A14A-3494E81CFBA0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff83e45000 - 0x7fff83e45fff com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff83f7f000 - 0x7fff841a9fe7 com.apple.CoreData (104.1 - 358.14) <6BB64605-8DA7-337D-A2AB-A3346A421CBD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff841aa000 - 0x7fff842b6fef libcrypto.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <FB999E54-C9BC-3A6D-9FE5-BFCC236775ED> /usr/lib/libcrypto.0.9.8.dylib
0x7fff842b7000 - 0x7fff842befff libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <0AB51EE2-E914-358C-AC19-47BC024BDAE7> /usr/lib/system/libcopyfile.dylib
0x7fff842d6000 - 0x7fff842dfff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
0x7fff8432b000 - 0x7fff84336fff com.apple.CommonAuth (2.2 - 2.0) <4F5302A5-867A-3F2E-9E4B-98FA011678F8> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff84337000 - 0x7fff8433efff libGFXShared.dylib (??? - ???) <D3598924-B167-372E-8C9F-1BBF68852542> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8434b000 - 0x7fff84366fff libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <DDB91E75-A2FA-331F-8069-999127AC6A9D> /usr/lib/libexpat.1.dylib
0x7fff84367000 - 0x7fff84369ff7 com.apple.print.framework.Print (7.4 - 247.3) <626C58D5-2841-3329-8C32-9F4A8353F3E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff8438d000 - 0x7fff84412ff7 com.apple.Heimdal (2.2 - 2.0) <52B0F371-D272-3C8E-B42F-04D3FDD8AD0D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff84413000 - 0x7fff84420fff com.apple.CrashReporterSupport (10.7.4 - 353) <6044CFB6-939E-3C73-BFBB-A8BBC096F135> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff84421000 - 0x7fff84447fff com.apple.framework.familycontrols (3.0 - 300) <6F0C58C0-22E7-3877-8CFA-1ED0CB3CE38B> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff84448000 - 0x7fff844a0ff7 libTIFF.dylib (??? - ???) <CF2005B6-5C29-3DCF-BDC2-7DB114ECD7A1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff844ff000 - 0x7fff8450dfff libdispatch.dylib (187.10.0 - compatibility 1.0.0) <8E03C652-922A-3399-93DE-9EA0CBFA0039> /usr/lib/system/libdispatch.dylib
0x7fff8450e000 - 0x7fff84537fff com.apple.CoreVideo (1.7 - 70.3) <9A9D4058-9935-3B0A-B1A6-27EB78D02249> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff850d6000 - 0x7fff850e1ff7 com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <6540EAF2-E3BF-3D2E-B4C1-F106180D6F20> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff850e9000 - 0x7fff8512dff7 com.apple.MediaKit (12 - 602) <0C2CBEDA-412F-3DDF-9C74-44114E5E0DB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8512e000 - 0x7fff85141ff7 libCRFSuite.dylib (??? - ???) <0B76941F-218E-30C8-B6DE-E15919F8DBEB> /usr/lib/libCRFSuite.dylib
0x7fff85142000 - 0x7fff8516eff7 com.apple.CoreServicesInternal (113.20 - 113.20) <786118E6-7D7E-3016-9FD5-A7CE411A251F> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff8516f000 - 0x7fff85269ff7 com.apple.DiskImagesFramework (10.7.4 - 331.7) <BEBA6D78-08E0-3B99-B77B-A5CBF3344834> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff8526a000 - 0x7fff8527cff7 libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
0x7fff8527d000 - 0x7fff85281ff7 com.apple.CommonPanels (1.2.5 - 94) <37C6540B-F8D1-355A-806C-F93D8FB522AB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff85282000 - 0x7fff852bdfff com.apple.LDAPFramework (3.2 - 120.2) <275D4298-C435-3E98-AA25-95D9D0A56550> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff852be000 - 0x7fff852fefe7 libGLImage.dylib (??? - ???) <0B7DAB2B-F1C6-39C7-B864-61EF683B6656> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff85312000 - 0x7fff85312fff libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
0x7fff85313000 - 0x7fff85316fff libCoreVMClient.dylib (??? - ???) <28CB0F3F-A202-391F-8CAC-FC9A1398A962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8533e000 - 0x7fff85382ff7 libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <B2A38D2C-7E82-34C5-8896-48C37B0E64A3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff85383000 - 0x7fff85387fff libdyld.dylib (195.5.0 - compatibility 1.0.0) <380C3F44-0CA7-3514-8080-46D1C9DF4FCD> /usr/lib/system/libdyld.dylib
0x7fff85586000 - 0x7fff85586fff com.apple.Carbon (153 - 153) <C1A30E01-E113-38A0-95CA-99360F92A37A> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff85587000 - 0x7fff858b3fff com.apple.HIToolbox (1.9 - ???) <CCB32DEA-D0CA-35D1-8019-E599C8007AB6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff858b4000 - 0x7fff85a11fff com.apple.audio.toolbox.AudioToolbox (1.7.3 - 1.7.3) <5F1E4695-BC74-3ADD-8345-627BCD68201A> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff85a14000 - 0x7fff85a22fff com.apple.NetAuth (3.1 - 3.1) <FE7EC4D7-5632-3B8D-9094-A0AC8D60EDEE> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff85a23000 - 0x7fff85aeaff7 com.apple.ColorSync (4.7.4 - 4.7.4) <590AFCDA-F10E-31FE-9B01-DA5FFE74C2BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff85aeb000 - 0x7fff85af0fff libcache.dylib (47.0.0 - compatibility 1.0.0) <1571C3AB-BCB2-38CD-B3B2-C5FC3F927C6A> /usr/lib/system/libcache.dylib
0x7fff85af1000 - 0x7fff85af6fff libGIF.dylib (??? - ???) <58A4492D-AAE7-3B8F-8B06-62867471A3EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff85afc000 - 0x7fff85be0ff7 com.apple.CoreServices.OSServices (478.50 - 478.50) <3D6AA4EF-C601-36C7-8F3A-A00964F01759> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff85be1000 - 0x7fff85be7fff libmacho.dylib (800.0.0 - compatibility 1.0.0) <165514D7-1BFA-38EF-A151-676DCD21FB64> /usr/lib/system/libmacho.dylib
0x7fff8601c000 - 0x7fff86449fff libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff86676000 - 0x7fff8667bfff com.apple.OpenDirectory (10.7 - 146) <A674AB55-6E3D-39AE-9F9B-9865D0193020> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff8667c000 - 0x7fff866a5fff libJPEG.dylib (??? - ???) <DFD81B8F-F4CB-347B-92B8-1AFFDA924A9B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff866a6000 - 0x7fff866b3fff libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <72C53E7B-C222-3BE5-9984-FDC328CC4846> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff866b4000 - 0x7fff866b4fff com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff86d36000 - 0x7fff8702bff7 com.apple.security (7.0 - 55148.6) <4535E500-973A-3BA7-AF65-DF5CF0658F02> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8702c000 - 0x7fff870d1fff com.apple.ink.framework (10.7.5 - 113) <1AE6676D-490A-36C2-B6CC-00F93AEB31DE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff870d2000 - 0x7fff87174fff com.apple.securityfoundation (5.0 - 55116) <A9311EF6-B7F7-3DA5-84E8-21BC9B2C3C69> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff87271000 - 0x7fff872a1ff7 com.apple.DictionaryServices (1.2.1 - 158.3) <5E2EBBFD-D520-3379-A431-11DAA844B8D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff872a2000 - 0x7fff872a8ff7 libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
0x7fff872a9000 - 0x7fff872c5ff7 com.apple.GenerationalStorage (1.0 - 126.1) <509F52ED-E54B-3FEF-B3C2-759387B826E6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff872c6000 - 0x7fff872d8ff7 libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
0x7fff872d9000 - 0x7fff872defff libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
0x7fff87346000 - 0x7fff87394fff libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
0x7fff873be000 - 0x7fff873cbff7 libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <3373D310-3B10-3DD1-B754-B7B138CD448D> /usr/lib/libbz2.1.0.dylib
0x7fff874b9000 - 0x7fff877dbfff com.apple.JavaScriptCore (7534.57 - 7534.57.3) <3A04B8FC-CFA6-3AEB-8FDF-B0525B5A4C82> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff877dc000 - 0x7fff87838ff7 com.apple.HIServices (1.21 - ???) <B012EE97-D1CD-3F4B-812D-9AC7E6852FE6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff87839000 - 0x7fff8783bfff libquarantine.dylib (36.7.0 - compatibility 1.0.0) <8D9832F9-E4A9-38C3-B880-E5210B2353C7> /usr/lib/system/libquarantine.dylib
0x7fff878fc000 - 0x7fff87901fff libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
0x7fff87902000 - 0x7fff87919fff com.apple.CFOpenDirectory (10.7 - 146) <E71AE4A2-F72B-35F2-9043-9F45CF75F11A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff87946000 - 0x7fff87988ff7 libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <BB770C22-8C57-365A-8716-4A3C36AE7BFB> /usr/lib/system/libcommonCrypto.dylib
0x7fff87989000 - 0x7fff879e4ff7 com.apple.opencl (2.0.19 - 2.0.19) <B05BF605-73B8-328F-A228-6FA59E1FC73A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff879e7000 - 0x7fff87a07fff libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <66C9F9BD-C7B3-30D4-B1A0-03C8A6392351> /usr/lib/system/libsystem_kernel.dylib
0x7fff87a08000 - 0x7fff8873ffff com.apple.WebCore (7534.57 - 7534.57.7) <33FCF30A-08C5-3169-B3B0-3A9462FA1A0D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff88740000 - 0x7fff888a7ff7 com.apple.CFNetwork (520.5.3 - 520.5.3) <1C11C214-1C70-3358-A709-69C84D999DB8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff888a8000 - 0x7fff888d0fff com.apple.PerformanceAnalysis (1.11 - 11) <8D4C6382-DD92-37A2-BCFC-E89951320848> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff888d1000 - 0x7fff889affff com.apple.DiscRecording (6.0.4 - 6040.4.1) <E6D5835F-EE3C-3814-A2EE-6962B5570EF1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff889fd000 - 0x7fff88a80fef com.apple.Metadata (10.7.0 - 627.37) <B9BEB598-B6F2-3BFF-A8F3-C3C87CD076AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff88a81000 - 0x7fff88f48fff FaceCoreLight (1.4.7 - compatibility 1.0.0) <BDD0E1DE-CF33-3AF8-B33B-4D1574CCC19D> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x7fff88fe1000 - 0x7fff88fe2ff7 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <739E6C83-AA52-3C6C-A680-B37FE2888A04> /usr/lib/system/libremovefile.dylib
0x7fff88fe3000 - 0x7fff89022fff com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff89023000 - 0x7fff89035ff7 libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
0x7fff8909f000 - 0x7fff8909ffff libOpenScriptingUtil.dylib (??? - ???) <A7847713-F410-39C0-884F-A7188A18E742> /usr/lib/libOpenScriptingUtil.dylib
0x7fff890e7000 - 0x7fff890e9fff com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff890ea000 - 0x7fff890fffff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff89a32000 - 0x7fff89d4bfff com.apple.Foundation (6.7.2 - 833.25) <22AAC369-B63C-3C55-8AC6-C3ECBA44DA7B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff89dfe000 - 0x7fff89e04fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff89e24000 - 0x7fff89e32ff7 libkxld.dylib (??? - ???) <01161870-E3B3-3F87-BA4A-0AA7A081F409> /usr/lib/system/libkxld.dylib
0x7fff89e34000 - 0x7fff89eaafff com.apple.CoreSymbolication (2.2 - 73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff89eba000 - 0x7fff89ebbfff liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
0x7fff89f8b000 - 0x7fff89fc6fff libsystem_info.dylib (??? - ???) <35F90252-2AE1-32C5-8D34-782C614D9639> /usr/lib/system/libsystem_info.dylib
0x7fff89fe6000 - 0x7fff8a0edfe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <EE02BB01-64C9-304D-9719-A35F5CD6D04C> /usr/lib/libsqlite3.dylib
0x7fff8a0ee000 - 0x7fff8a0eefff com.apple.Cocoa (6.6 - ???) <7EC4D759-B2A6-3A99-AC75-809FED1500C6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8a0ef000 - 0x7fff8a10cff7 com.apple.openscripting (1.3.3 - ???) <F5E34F54-CE85-334B-8F25-53581D43960C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8a1ba000 - 0x7fff8a1c5ff7 libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
0x7fff8a1c6000 - 0x7fff8a1c9ff7 com.apple.securityhi (4.0 - 1) <7146CB8E-B754-3B0E-A74E-77E9138A81C5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8a5a6000 - 0x7fff8a685fff com.apple.ImageIO.framework (3.1.2 - 588) <37F047A9-48E3-3AF7-8931-462D63BE6121> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8a686000 - 0x7fff8a694fff com.apple.HelpData (2.1.2 - 72.2) <363E36C5-F7C0-34A6-83D3-97C8FB6511F0> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff8a695000 - 0x7fff8a699fff libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <35D606B1-7AD9-38E3-A2A9-E92B904BDDE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff8a69a000 - 0x7fff8a6daff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <7D2E5016-A960-3ADE-B042-F74063E79550> /usr/lib/libcups.2.dylib
0x7fff8a6db000 - 0x7fff8a7b8fef libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
0x7fff8ac03000 - 0x7fff8ac09fff IOSurface (??? - ???) <77C6757B-D357-3E34-9424-48F962B5CC9C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff8ac0a000 - 0x7fff8ac0afff com.apple.Accelerate (1.7 - Accelerate 1.7) <82DDF6F5-FBC3-323D-B71D-CF7ABC5CF568> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8ac4c000 - 0x7fff8ac79fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <7BEBB139-50BB-3112-947A-F4AA168F991C> /usr/lib/libSystem.B.dylib
0x7fff8ac7a000 - 0x7fff8ac8eff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff8ac8f000 - 0x7fff8acaefff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <0635C52D-DD53-3721-A488-4C6E95607A74> /usr/lib/libresolv.9.dylib
0x7fff8acaf000 - 0x7fff8ad45ff7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) <642D8D54-F9F5-3FBB-A96C-EEFE94C6278B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8aec3000 - 0x7fff8af47ff7 com.apple.ApplicationServices.ATS (317.13.0 - ???) <A05126F9-7DC9-3EA7-8D94-53C6113730C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8b23a000 - 0x7fff8b40eff7 com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8b40f000 - 0x7fff8b413fff libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
0x7fff8b414000 - 0x7fff8b4aeff7 com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8b4af000 - 0x7fff8b7cbfff com.apple.CoreServices.CarbonCore (960.25 - 960.25) <4FC1AB30-022C-3C67-AC46-FDCBFCB7EEDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff8b7cc000 - 0x7fff8b818ff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <0A7F1982-B4EA-3424-A0C7-FE46C6224F03> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff8b819000 - 0x7fff8b90efff libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
0x7fff8b90f000 - 0x7fff8ba1cfff libJP2.dylib (??? - ???) <1CF69239-3D3D-30CE-AC7B-C7E8C9166BC2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff8ba3a000 - 0x7fff8ba44ff7 liblaunch.dylib (392.39.0 - compatibility 1.0.0) <8C235D13-2928-30E5-9E12-2CC3D6324AE2> /usr/lib/system/liblaunch.dylib
0x7fff8bdf4000 - 0x7fff8be27ff7 com.apple.GSS (2.2 - 2.0) <C86012C5-B613-3199-B1B3-A1494EE5E43C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff8be72000 - 0x7fff8bec4ff7 libGLU.dylib (??? - ???) <DB906997-0F70-3469-BA0E-2F1DDBEAD8D5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8bf54000 - 0x7fff8bfbfff7 com.apple.framework.IOKit (2.0 - ???) <FE838BB6-D42E-3291-A1A0-6F53FC970261> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8bfc0000 - 0x7fff8c033fff libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
0x7fff8c034000 - 0x7fff8c618fff libBLAS.dylib (??? - ???) <C34F6D88-187F-33DC-8A68-C0C9D1FA36DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff8c619000 - 0x7fff8c689fff com.apple.datadetectorscore (3.0 - 179.4) <9C01D16F-75A9-3BDD-B91A-F0F32261A2E7> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8c68a000 - 0x7fff8c691fff com.apple.CommerceCore (1.0 - 17.1) <B6BFA182-9DC9-3543-89AE-F82EB9AF1CAB> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff8c6b6000 - 0x7fff8c6f0fe7 com.apple.DebugSymbols (2.1 - 87) <ED2B177C-4146-3715-91DF-D99A8ED5449A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8c6f1000 - 0x7fff8c708fff com.apple.MultitouchSupport.framework (231.4 - 231.4) <10A978D1-8781-33F0-BE45-60C9171F7278> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8c709000 - 0x7fff8c893ff7 com.apple.WebKit (7534.57 - 7534.57.7) <15AA1A2E-DCAC-35CE-89DF-0FF7149198CD> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8c894000 - 0x7fff8c89bfff com.apple.NetFS (4.0 - 4.0) <433EEE54-E383-3505-9154-45B909FD3AF0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff8c89c000 - 0x7fff8c8fcfff libvDSP.dylib (325.4.0 - compatibility 1.0.0) <3A7521E6-5510-3FA7-AB65-79693A7A5839> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8c94f000 - 0x7fff8c95eff7 libxar-nossl.dylib (??? - ???) <A6ABBFB9-E4ED-38AD-BBBB-F9958B9CEFB5> /usr/lib/libxar-nossl.dylib
0x7fff8cafa000 - 0x7fff8cb09fff com.apple.opengl (1.8.1 - 1.8.1) <51B34133-CEE3-3FC6-82AC-ADF567AE673C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8cb0a000 - 0x7fff8cbeee5f libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <871E688B-CF57-3BC7-80D6-F6476DFF109B> /usr/lib/libobjc.A.dylib
0x7fff8cbef000 - 0x7fff8cbf0ff7 libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
0x7fff8d092000 - 0x7fff8d145ff7 com.apple.CoreText (220.22.0 - ???) <A7A1096F-A211-3775-BA33-08FE98D27F08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8d146000 - 0x7fff8d19aff7 com.apple.ScalableUserInterface (1.0 - 1) <33563775-C662-313D-B7FA-3D575A9F3D41> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x7fff8d19b000 - 0x7fff8d1a3fff libsystem_dnssd.dylib (??? - ???) <584B321E-5159-37CD-B2E7-82E069C70AFB> /usr/lib/system/libsystem_dnssd.dylib
0x7fff8d1a4000 - 0x7fff8d1dffff libssl.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <B5120F7F-6FD7-3E0B-AAB8-E9A8D72451BC> /usr/lib/libssl.0.9.8.dylib
0x7fff8d1e0000 - 0x7fff8d234fff libFontRegistry.dylib (??? - ???) <60FF9C2C-5E44-3C49-8A08-F26101898F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff8d235000 - 0x7fff8d275fff libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
0x7fff8d2a7000 - 0x7fff8d2e8fff com.apple.QD (3.40.1 - ???) <13ACC7F4-B004-3370-B575-6D06447EE428> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8d2e9000 - 0x7fff8d41ffff com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff8d420000 - 0x7fff8d522fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <AFBB22B7-07AE-3F2E-B88C-70BEEBFB8A86> /usr/lib/libxml2.2.dylib
0x7fff8d523000 - 0x7fff8d79eff7 com.apple.RawCamera.bundle (4.09 - 711) <0040632D-09A9-32DE-98E8-BFA99F9F6526> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff8d7ac000 - 0x7fff8d7c9fff libxpc.dylib (77.19.0 - compatibility 1.0.0) <9F57891B-D7EF-3050-BEDD-21E7C6668248> /usr/lib/system/libxpc.dylib
0x7fff8d7ca000 - 0x7fff8d82cff7 com.apple.Symbolication (1.3 - 91) <B072970E-9EC1-3495-A1FA-D344C6E74A13> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff8d82d000 - 0x7fff8d8ceff7 com.apple.LaunchServices (480.42 - 480.42) <A69F9426-05CE-3312-89FD-BC063DA66DBF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8d8cf000 - 0x7fff8d937ff7 com.apple.coreui (1.2.2 - 165.11) <9316266A-39CA-3EC7-9C9E-726462CEFF4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff8d938000 - 0x7fff8d963ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
0x7fff8d964000 - 0x7fff8d97aff7 com.apple.ImageCapture (7.1.0 - 7.1.0) <1AD40E02-2126-377B-A0D2-CBB21D932558> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff8dc46000 - 0x7fff8dc47fff libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8dec1000 - 0x7fff8dec2ff7 libsystem_sandbox.dylib (??? - ???) <5459F293-E1F2-33B3-B9B2-2ABB7B915B62> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8dec3000 - 0x7fff8df09fff libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <066449E4-406B-3ABC-9DB8-E62777498154> /usr/lib/libcurl.4.dylib
0x7fff8df0a000 - 0x7fff8df11fff libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <1116CD6D-E7AD-375F-A691-B9DF6609FEAD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x7fff8df12000 - 0x7fff8e017fff libFontParser.dylib (??? - ???) <D2E56B6E-3182-3667-A78C-4172C435523A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8e018000 - 0x7fff8e01bfff com.apple.help (1.3.2 - 42) <BF14DE49-F7E8-336F-81FB-BBDF2DB3AC09> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8e01c000 - 0x7fff8e01cfff com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8e3c8000 - 0x7fff8e3ecfff com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8e3ed000 - 0x7fff8e403fff libGL.dylib (??? - ???) <A4876AE9-DDFE-3B9A-874E-09BC29D46C39> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8e404000 - 0x7fff8e404fff com.apple.ApplicationServices (41 - 41) <89B6AD5B-5C75-3E83-8C2B-AA7F4C55E400> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8e405000 - 0x7fff8e407fff libCVMSPluginSupport.dylib (??? - ???) <982F1ED4-3CBB-3161-8BEA-8A980C27FCC1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8e408000 - 0x7fff8e60afff libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <0176782F-9526-3905-813A-7A5676EC2C86> /usr/lib/libicucore.A.dylib
0x7fff8e60b000 - 0x7fff8e60bfff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8e69f000 - 0x7fff8f03da27 com.apple.CoreGraphics (1.600.0 - ???) <576777EA-921B-3D94-98C3-40A9CF8EBD18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8f03e000 - 0x7fff8f0a6ff7 com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <9987DC46-2A96-3BA0-B88B-04E573C0AD9B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8f850000 - 0x7fff8f853fff libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8f8a8000 - 0x7fff8f8adff7 libsystem_network.dylib (??? - ???) <5DE7024E-1D2D-34A2-80F4-08326331A75B> /usr/lib/system/libsystem_network.dylib
0x7fff8f8da000 - 0x7fff8f8dbfff libunc.dylib (24.0.0 - compatibility 1.0.0) <337960EE-0A85-3DD0-A760-7134CF4C0AFF> /usr/lib/system/libunc.dylib
0x7fff8f925000 - 0x7fff8f9a0ff7 com.apple.print.framework.PrintCore (7.1 - 366.3) <C5F39A82-0E77-3AD6-906A-20DD2EE8D374> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8f9a1000 - 0x7fff8fa17ff7 libc++.1.dylib (28.4.0 - compatibility 1.0.0) <A24FC3DA-4FFA-3DD2-9DCC-2B8D1B3BF97C> /usr/lib/libc++.1.dylib
0x7fff8fa53000 - 0x7fff8fbf3ff7 com.apple.QuartzCore (1.7 - 270.5) <19E5E0AB-DAA9-3F97-988C-D9A46AFB9C04> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff8fbf4000 - 0x7fff8fc15fff libPng.dylib (??? - ???) <E2B52527-4D0C-3595-BB13-8E8EF364E998> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8fc16000 - 0x7fff8fc45fff com.apple.shortcut (2.1 - 2.1) <BE0AB36A-6911-356B-8784-D39175ACAF55> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff8fd82000 - 0x7fff8fff6fff com.apple.CoreImage (7.99.1 - 1.0.1) <4BB09B79-275B-364C-9466-0FF36ABB1218> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 24
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1912
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=190.9M resident=86.2M(45%) swapped_out_or_unallocated=104.7M(55%)
Writable regions: Total=84.6M written=3336K(4%) resident=30.8M(36%) swapped_out=0K(0%) unallocated=53.7M(64%)
REGION TYPE VIRTUAL
CG backing stores 7516K
CG image 12K
CG raster data 128K
CG shared images 1224K
CoreGraphics 16K
CoreImage 4K
CoreServices 8068K
MALLOC 44.0M
MALLOC guard page 48K
Memory tag=240 4K
Memory tag=242 12K
Memory tag=251 8K
OpenCL 8K
STACK GUARD 56.0M
Stack 9752K
VM_ALLOCATE 16.2M
__CI_BITMAP 80K
__DATA 21.9M
__IMAGE 528K
__LINKEDIT 50.3M
__TEXT 140.6M
__UNICODE 544K
mapped file 40.9M
shared memory 1372K
TOTAL 398.5M
Model: MacBookPro8,1, BootROM MBP81.0047.B27, 2 processors, Intel Core i5, 2.4 GHz, 8 GB, SMC 1.68f99
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x802C, 0x31364A54463531323634485A2D3147344D31
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x802C, 0x31364A54463531323634485A2D3147344D31
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: TOSHIBA MK5065GSXF, 500.11 GB
Serial ATA Device: OPTIARC DVD RW AD-5970H
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 3
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 2
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 5
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 8
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
FireWire Device: My Passport 071D, WD, 800mbit_speed
when trying to access the update that kept popping up. (So far not able to update to the latest build)
Have been trying to upgrade since yesterday and am unable to.
Why is the quote icon missing from this page?
problem found with loading tracks in automix. the waveform shows that the track is not complete but the track is fine when played on vdj7 or any other media player.. relaunching the application clears it up for that song but other songs in the playlist experience the same behavior.
I think the mac crash report affected the page layout. If you fullscreen your browser it will be present.
Can't update to 1806.
../src/osx/cocoa/evtloop.mm(525): assert "m_modalSession != NULL" failed in EndModalSession(): no modal session active
Call stack:
[00] 0x000000010e24673c
[01] 0x000000010e24649b
[02] 0x000000010e2463ae
[03] 0x000000010e2467cf
[04] 0x000000010dfa104e
[05] -[NSObject performSelector:withObject:]
[06] -[NSApplication sendAction:to:from:]
[07] -[NSControl sendAction:to:]
[08] -[NSCell _sendActionFrom:]
[09] -[NSCell trackMouse:inRect:ofView:untilMouseUp:]
[10] -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:]
[11] -[NSControl mouseDown:]
[12] 0x000000010e00f682
[13] -[NSWindow sendEvent:]
[14] 0x000000010dfff095
[15] -[NSApplication sendEvent:]
[16] 0x000000010df7fa38
[17] 0x000000010dff5bc4
[18] 0x000000010e226c54
[19] 0x000000010e1a3a95
[20] 0x000000010df83514
New crash while working in config (1806):
Process: VirtualDJ [979]
Version: 8.0.0 (8.0.1806)
Parent Process: launchd [258]
Date/Time: 2014-05-27 23:31:54.954 -0400
Report Version: 9
Interval Since Last Report: 11869492 sec
Crashes Since Last Report: 9
Per-App Interval Since Last Report: 24172 sec
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000235
VM Regions Near 0x235:
__TEXT 000000010dadc000-000000010f0b9000 [ 21.9M] r-x/rwx SM=COW /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
objc[979]: garbage collection is OFF
0 com.atomixproductions.virtualdj 0x000000010ded165a 0x10dadc000 + 4150874
1 com.atomixproductions.virtualdj 0x000000010decd782 0x10dadc000 + 4134786
2 com.apple.AppKit 0x00007fff8315aece -[NSWindow sendEvent:] + 6872
3 com.atomixproductions.virtualdj 0x000000010debd1f5 0x10dadc000 + 4067829
4 com.apple.AppKit 0x00007fff830f43a5 -[NSApplication sendEvent:] + 5593
5 com.atomixproductions.virtualdj 0x000000010de3db98 0x10dadc000 + 3546008
6 com.apple.AppKit 0x00007fff8308aa0e -[NSApplication run] + 555
7 com.atomixproductions.virtualdj 0x000000010deb3834 0x10dadc000 + 4028468
8 com.atomixproductions.virtualdj 0x000000010e0e4db4 0x10dadc000 + 6327732
9 com.atomixproductions.virtualdj 0x000000010e061bf5 0x10dadc000 + 5790709
10 com.atomixproductions.virtualdj 0x000000010e02f191 0x10dadc000 + 5583249
11 com.atomixproductions.virtualdj 0x000000010de7c84a 0x10dadc000 + 3803210
12 com.atomixproductions.virtualdj 0x000000010e090437 0x10dadc000 + 5981239
13 com.atomixproductions.virtualdj 0x000000010dbc39a2 0x10dadc000 + 948642
14 com.atomixproductions.virtualdj 0x000000010daddf04 0x10dadc000 + 7940
Thread 2:
0 libsystem_kernel.dylib 0x00007fff879fdbca __psynch_cvwait + 10
1 libsystem_c.dylib 0x00007fff8a72d274 _pthread_cond_wait + 840
2 com.atomixproductions.virtualdj 0x000000010dbb8c38 0x10dadc000 + 904248
3 com.atomixproductions.virtualdj 0x000000010dae4203 0x10dadc000 + 33283
4 com.atomixproductions.virtualdj 0x000000010dae41cd 0x10dadc000 + 33229
5 libsystem_c.dylib 0x00007fff8a7298bf _pthread_start + 335
6 libsystem_c.dylib 0x00007fff8a72cb75 thread_start + 13
Thread 3:
2 com.atomixproductions.virtualdj 0x000000010dbb8c72 0x10dadc000 + 904306
Thread 4:
Thread 5:
Thread 6:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff879fc67a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff879fbd71 mach_msg + 73
2 com.apple.audio.CoreAudio 0x00007fff8f06aeb3 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, unsigned int) + 93
3 com.apple.audio.CoreAudio 0x00007fff8f06af05 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 37
4 com.apple.audio.CoreAudio 0x00007fff8f064568 HALC_ProxyIOContext::IOWorkLoop() + 888
5 com.apple.audio.CoreAudio 0x00007fff8f064151 HALC_ProxyIOContext::IOThreadEntry(void*) + 73
6 com.apple.audio.CoreAudio 0x00007fff8f06400c HALB_IOThread::Entry(void*) + 78
7 libsystem_c.dylib 0x00007fff8a7298bf _pthread_start + 335
8 libsystem_c.dylib 0x00007fff8a72cb75 thread_start + 13
Thread 7:
2 com.apple.framework.IOKit 0x00007fff8bf9e139 io_connect_method + 431
3 com.apple.framework.IOKit 0x00007fff8bf58e0b IOConnectCallMethod + 352
4 com.apple.driver.AppleIntelHD3000GraphicsGLDriver 0x0000000116c8ac4d GhalInterface::getCommandBuffer(unsigned char**, unsigned char**, unsigned int*, unsigned int*) + 171
5 com.apple.driver.AppleIntelHD3000GraphicsGLDriver 0x0000000116cafe21 GHAL3D::CPrivateCommandTransport::FlushCommandBuffer(GHAL3D::FLUSH_TYPE, unsigned char) + 317
6 com.apple.driver.AppleIntelHD3000GraphicsGLDriver 0x0000000116cafbda g575SubmitPacketsToken + 46
7 libGPUSupport.dylib 0x00000001113c0de5 gldFlushObject + 95
8 GLEngine 0x0000000116a53802 gleEvaluateTextureImageChange + 236
9 GLEngine 0x0000000116922060 glTexImage2D_Exec + 671
10 libGL.dylib 0x00007fff8e3f0713 glTexImage2D + 73
11 com.atomixproductions.virtualdj 0x000000010dd527f1 0x10dadc000 + 2582513
12 com.atomixproductions.virtualdj 0x000000010db9ec75 0x10dadc000 + 797813
13 com.atomixproductions.virtualdj 0x000000010dd51c65 0x10dadc000 + 2579557
14 com.atomixproductions.virtualdj 0x000000010ddf2d29 0x10dadc000 + 3239209
15 com.atomixproductions.virtualdj 0x000000010ddf0f1a 0x10dadc000 + 3231514
16 com.atomixproductions.virtualdj 0x000000010ddef572 0x10dadc000 + 3224946
17 com.atomixproductions.virtualdj 0x000000010ddcff15 0x10dadc000 + 3096341
18 com.atomixproductions.virtualdj 0x000000010dcfd1f7 0x10dadc000 + 2232823
19 com.atomixproductions.virtualdj 0x000000010dcfd1f7 0x10dadc000 + 2232823
20 com.atomixproductions.virtualdj 0x000000010dcfd1f7 0x10dadc000 + 2232823
21 com.atomixproductions.virtualdj 0x000000010dcfd1f7 0x10dadc000 + 2232823
22 com.atomixproductions.virtualdj 0x000000010dcfd1f7 0x10dadc000 + 2232823
23 com.atomixproductions.virtualdj 0x000000010ddcff15 0x10dadc000 + 3096341
24 com.atomixproductions.virtualdj 0x000000010ddc11f3 0x10dadc000 + 3035635
25 com.atomixproductions.virtualdj 0x000000010dcb8177 0x10dadc000 + 1950071
26 com.atomixproductions.virtualdj 0x000000010dcda778 0x10dadc000 + 2090872
27 com.atomixproductions.virtualdj 0x000000010dae41f9 0x10dadc000 + 33273
28 com.atomixproductions.virtualdj 0x000000010dae41cd 0x10dadc000 + 33229
29 libsystem_c.dylib 0x00007fff8a7298bf _pthread_start + 335
30 libsystem_c.dylib 0x00007fff8a72cb75 thread_start + 13
Thread 8:
0 libsystem_kernel.dylib 0x00007fff879fddf2 __select + 10
1 com.atomixproductions.virtualdj 0x000000010daec6d5 0x10dadc000 + 67285
2 com.atomixproductions.virtualdj 0x000000010dae41f9 0x10dadc000 + 33273
3 com.atomixproductions.virtualdj 0x000000010dae41cd 0x10dadc000 + 33229
4 libsystem_c.dylib 0x00007fff8a7298bf _pthread_start + 335
5 libsystem_c.dylib 0x00007fff8a72cb75 thread_start + 13
Thread 9:
2 com.apple.audio.midi.CoreMIDI 0x000000010f93a5be XServerMachPort::ReceiveMessage(int&, void*, int&) + 96
3 com.apple.audio.midi.CoreMIDI 0x000000010f95b653 MIDIProcess::RunMIDIInThread() + 207
4 com.apple.audio.midi.CoreMIDI 0x000000010f93b96a XThread::RunHelper(void*) + 10
5 com.apple.audio.midi.CoreMIDI 0x000000010f93b396 CAPThread::Entry(CAPThread*) + 98
Thread 10:
2 com.atomixproductions.virtualdj 0x000000010e3c1058 0x10dadc000 + 9326680
3 libsystem_c.dylib 0x00007fff8a7298bf _pthread_start + 335
4 libsystem_c.dylib 0x00007fff8a72cb75 thread_start + 13
Thread 11:
2 com.apple.CoreFoundation 0x00007fff8b26a50c __CFRunLoopServiceMachPort + 188
3 com.apple.CoreFoundation 0x00007fff8b272c74 __CFRunLoopRun + 1204
4 com.apple.CoreFoundation 0x00007fff8b272486 CFRunLoopRunSpecific + 230
5 com.apple.CoreFoundation 0x00007fff8b28219f CFRunLoopRun + 95
6 com.atomixproductions.virtualdj 0x000000010e3c181d 0x10dadc000 + 9328669
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
rax: 0x0000000000000005 rbx: 0x00007fd8f486ef90 rcx: 0x00000000000ed690 rdx: 0x00007fd8f80b9590
rdi: 0x00007fff6d6db138 rsi: 0x00007fd8f8000000 rbp: 0x00007fff6d6db480 rsp: 0x00007fff6d6db3e0
r8: 0x0000000000000004 r9: 0x00007fd8f75aedf0 r10: 0x000000005c8361f0 r11: 0x0000000037b664be
r12: 0x00007fff74295f60 r13: 0x00007fd8f8174fb0 r14: 0x00007fd8f8174fb0 r15: 0x00007fff6d6db301
rip: 0x000000010ded165a rfl: 0x0000000000010202 cr2: 0x0000000000000235
Logical CPU: 3
Binary Images:
0x10dadc000 - 0x10f0b8f4f +com.atomixproductions.virtualdj (8.0.0 - 8.0.1806) <01D356B9-3508-32BF-9D21-07BA7F2D8164> /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
0x10f90b000 - 0x10f918ff7 +com.googlecode.google-breakpad (??? - 1.0) <9A5F89A4-5EA3-339F-BC47-6DF8D64238C6> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
0x10f92b000 - 0x10f97cff7 com.apple.audio.midi.CoreMIDI (1.8 - 42) <10BAC42F-ACFE-3EBC-869A-2847A0770CE8> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10f9a8000 - 0x10f9cdff7 +breakpadUtilities.dylib (??? - ???) <753EEC59-5853-36C1-BD7A-CB38123F77E5> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib
0x1111da000 - 0x1111f9fff com.apple.IOFireWireLib (4.4.8 - 4.4.8) <51398B7F-1BB2-3461-9582-1ABF3F35B635> /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
0x1112e0000 - 0x1112e4fff com.apple.audio.AudioIPCPlugIn (1.2.3 - 1.2.3) <F94D690D-3196-3B01-B798-09708367D28D> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x1112e9000 - 0x1112eefff com.apple.audio.AppleHDAHALPlugIn (2.2.5 - 2.2.5a5) <4EC4981B-68AE-357E-960F-3D4603A61E9F> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1113ba000 - 0x1113c8fff libGPUSupport.dylib (??? - ???) <9FF8DDA2-7CB1-3888-8AAE-227C7691CB98> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x1113cf000 - 0x1113d9fef libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <4572AD1E-D1D1-3412-AFCC-D37037B1FAB5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x1113e6000 - 0x111414ff7 GLRendererFloat (??? - ???) <06CA5D0B-BC5F-3CC7-836D-A02F7DB92BE8> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x11141d000 - 0x111420ff7 libCoreFSCache.dylib (??? - ???) <0D155750-7910-32C5-8327-924FC1089442> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x1142d6000 - 0x1142daff7 libFontRegistryUI.dylib (??? - ???) <6EFD0158-64F7-3A65-92E3-875AD0382A5C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x11690d000 - 0x116ac5fff GLEngine (??? - ???) <59179FEC-D0E2-38B3-BD49-765506A645AC> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x116afc000 - 0x116c56fff libGLProgrammability.dylib (??? - ???) <90390984-70BC-365C-AB3E-16C35C4240CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x116c88000 - 0x11706ffe7 com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.32.12 - 7.3.2) <5C9C9474-BA99-33A6-BAD8-628224491FED> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsGLDriver
0x7fff6d6dc000 - 0x7fff6d710baf dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
0x7fff8539a000 - 0x7fff85497ff7 com.apple.avfoundation (2.0 - 180.50) <A2EAE4E6-4DBA-3AAB-A387-7E72B93B6DA9> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff85be8000 - 0x7fff8601bff7 com.apple.VideoToolbox (1.0 - 705.94) <72AD524C-0616-3C69-BA1F-8D444F97F5A2> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff88fc6000 - 0x7fff88fe0fff com.apple.CoreMediaAuthoring (2.0 - 891) <C7A92C52-AD9F-3CF1-86D5-C0714118935C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff8a7b9000 - 0x7fff8a800ff7 com.apple.CoreMedia (1.0 - 705.94) <700C6863-7A8F-34FA-8B1D-7659EC95000B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff8c8fd000 - 0x7fff8c94eff7 com.apple.CoreMediaIO (216.0 - 3199.8) <4D3FE512-E943-34E3-A7A5-2EC2E3854E28> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff8c963000 - 0x7fff8c9b6fff com.apple.AppleVAFramework (5.0.16 - 5.0.16) <6F9A4BCE-8B99-3144-BCF7-B4299B27F6E9> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff8e01d000 - 0x7fff8e3c7fe7 com.apple.MediaToolbox (1.0 - 705.94) <0719E69C-3275-3BD9-AD04-27DBADEB6E03> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff8f0a7000 - 0x7fff8f84ffff com.apple.CoreAUC (6.16.12 - 6.16.12) <EF535959-14FE-3B61-9C32-DF4C54B8F12D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
task_for_pid: 3
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 1554
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=214.6M resident=85.2M(40%) swapped_out_or_unallocated=129.4M(60%)
Writable regions: Total=369.7M written=180.9M(49%) resident=273.0M(74%) swapped_out=0K(0%) unallocated=96.7M(26%)
REGION TYPE VIRTUAL
(null) (reserved) 40K reserved VM address space (unallocated)
CG backing stores 6632K
CG image 220K
CG raster data 1008K
CG shared images 3448K
CoreGraphics 16K
CoreServices 8068K
IOKit 39.7M
MALLOC 278.3M
MALLOC guard page 64K
MALLOC_LARGE (reserved) 696K reserved VM address space (unallocated)
Memory tag=240 4K
Memory tag=242 12K
OpenGL GLSL 896K
STACK GUARD 56.1M
Stack 16.7M
VM_ALLOCATE 16.2M
__CI_BITMAP 80K
__DATA 22.7M
__IMAGE 528K
__LINKEDIT 51.9M
__TEXT 162.6M
__UNICODE 544K
mapped file 41.1M
shared memory 3080K
TOTAL 710.2M
TOTAL, minus reserved VM space 709.5M
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 3
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 5
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 4
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
another crash within 10 min of each other one was while removing a track in browser. the other was while clicking on yes for new update:
Process: VirtualDJ [1141]
Date/Time: 2014-05-28 00:54:01.159 -0400
Report Version: 9
Interval Since Last Report: 11874413 sec
Crashes Since Last Report: 10
Per-App Interval Since Last Report: 28455 sec
Per-App Crashes Since Last Report: 2
objc[1141]: garbage collection is OFF
1 com.atomixproductions.virtualdj 0x000000010192811b 0x10152d000 + 4174107
2 com.atomixproductions.virtualdj 0x0000000101a81bd8 0x10152d000 + 5589976
3 com.atomixproductions.virtualdj 0x0000000101a81826 0x10152d000 + 5589030
4 com.atomixproductions.virtualdj 0x0000000101a824e4 0x10152d000 + 5592292
5 com.atomixproductions.virtualdj 0x0000000101a7fe50 0x10152d000 + 5582416
6 com.atomixproductions.virtualdj 0x000000010198eae7 0x10152d000 + 4594407
7 com.atomixproductions.virtualdj 0x00000001017c2e50 0x10152d000 + 2711120
8 com.atomixproductions.virtualdj 0x000000010162db8f 0x10152d000 + 1051535
9 com.atomixproductions.virtualdj 0x00000001016e4493 0x10152d000 + 1799315
10 com.atomixproductions.virtualdj 0x00000001016e3a60 0x10152d000 + 1796704
11 com.atomixproductions.virtualdj 0x00000001016919a9 0x10152d000 + 1460649
12 com.atomixproductions.virtualdj 0x0000000101b5589c 0x10152d000 + 6457500
13 com.atomixproductions.virtualdj 0x0000000101b555fb 0x10152d000 + 6456827
14 com.atomixproductions.virtualdj 0x0000000101b5550e 0x10152d000 + 6456590
15 com.atomixproductions.virtualdj 0x00000001019f0b44 0x10152d000 + 4995908
16 com.atomixproductions.virtualdj 0x0000000101b55591 0x10152d000 + 6456721
17 com.atomixproductions.virtualdj 0x0000000101b5592f 0x10152d000 + 6457647
18 com.atomixproductions.virtualdj 0x00000001019ac710 0x10152d000 + 4716304
19 com.atomixproductions.virtualdj 0x00000001018b6fb2 0x10152d000 + 3710898
39 com.atomixproductions.virtualdj 0x0000000101904771 0x10152d000 + 4028273
40 com.atomixproductions.virtualdj 0x0000000101b35b26 0x10152d000 + 6327078
41 com.atomixproductions.virtualdj 0x0000000101b35ce2 0x10152d000 + 6327522
42 com.atomixproductions.virtualdj 0x0000000101904d41 0x10152d000 + 4029761
43 com.atomixproductions.virtualdj 0x0000000101b35db4 0x10152d000 + 6327732
44 com.atomixproductions.virtualdj 0x0000000101ab2bf5 0x10152d000 + 5790709
45 com.atomixproductions.virtualdj 0x0000000101892674 0x10152d000 + 3561076
46 com.atomixproductions.virtualdj 0x00000001015e2eb7 0x10152d000 + 745143
47 com.atomixproductions.virtualdj 0x0000000101691cca 0x10152d000 + 1461450
48 com.atomixproductions.virtualdj 0x0000000101614aa5 0x10152d000 + 948901
49 com.atomixproductions.virtualdj 0x000000010188eece 0x10152d000 + 3546830
50 com.atomixproductions.virtualdj 0x0000000101ae141f 0x10152d000 + 5981215
51 com.atomixproductions.virtualdj 0x00000001016149a2 0x10152d000 + 948642
52 com.atomixproductions.virtualdj 0x000000010152ef04 0x10152d000 + 7940
Thread 2:: com.apple.appkit-heartbeat
Thread 3:: Dispatch queue: NSPersistentUI Work
0 com.apple.CoreFoundation 0x00007fff8b26b29e -[__NSArrayM objectAtIndex:] + 30
1 com.apple.AppKit 0x00007fff830e9ee6 -[NSPersistentUIManager windowInfoForWindowID:createIfNecessary:] + 108
2 com.apple.AppKit 0x00007fff831891bb __-[NSPersistentUIManager changeWindow:toStatus:withConditionalGeneration:]_block_invoke_1 + 85
3 libdispatch.dylib 0x00007fff84500a82 _dispatch_call_block_and_release + 18
4 libdispatch.dylib 0x00007fff845022d2 _dispatch_queue_drain + 264
5 libdispatch.dylib 0x00007fff8450212e _dispatch_queue_invoke + 54
6 libdispatch.dylib 0x00007fff84501928 _dispatch_worker_thread2 + 198
7 libsystem_c.dylib 0x00007fff8a72b3da _pthread_wqthread + 316
8 libsystem_c.dylib 0x00007fff8a72cb85 start_wqthread + 13
rax: 0x0000000000000000 rbx: 0x0000000000000002 rcx: 0x00007fff61124b98 rdx: 0x0000000000000000
rdi: 0x0000000000000475 rsi: 0x0000000000000005 rbp: 0x00007fff61124c30 rsp: 0x00007fff61124b98
r8: 0x0000000000000004 r9: 0x00007f95fbba4200 r10: 0x00000000000a33d0 r11: 0xffffff80002dad60
r12: 0x00000000000006cb r13: 0x00007fff61124dc0 r14: 0x00007fff61124d20 r15: 0x0000000102c81060
rip: 0x00007fff879fd82a rfl: 0x0000000000000206 cr2: 0x00007fff6116232c
Logical CPU: 0
Binary Images:
0x10152d000 - 0x102b09f4f +com.atomixproductions.virtualdj (8.0.0 - 8.0.1806) <01D356B9-3508-32BF-9D21-07BA7F2D8164> /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
0x103358000 - 0x103365ff7 +com.googlecode.google-breakpad (??? - 1.0) <9A5F89A4-5EA3-339F-BC47-6DF8D64238C6> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
0x103378000 - 0x1033c9ff7 com.apple.audio.midi.CoreMIDI (1.8 - 42) <10BAC42F-ACFE-3EBC-869A-2847A0770CE8> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x1033f1000 - 0x103416ff7 +breakpadUtilities.dylib (??? - ???) <753EEC59-5853-36C1-BD7A-CB38123F77E5> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib
0x104e2b000 - 0x104e2eff7 libCoreFSCache.dylib (??? - ???) <0D155750-7910-32C5-8327-924FC1089442> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x107905000 - 0x10790ffef libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <4572AD1E-D1D1-3412-AFCC-D37037B1FAB5> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
0x1079ac000 - 0x1079acff3 +cl_kernels (??? - ???) <823460DE-EC2A-4F04-9254-3C0DE2F2593E> cl_kernels
0x1079ae000 - 0x107a4dff7 unorm8_bgra.dylib (2.0.19 - compatibility 1.0.0) <47DA7D73-C52D-322F-A08F-4DB320A65373> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff6112d000 - 0x7fff61161baf dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
task_for_pid: 41
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 2271
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=208.8M resident=96.8M(46%) swapped_out_or_unallocated=112.0M(54%)
Writable regions: Total=111.3M written=7448K(7%) resident=59.7M(54%) swapped_out=0K(0%) unallocated=51.6M(46%)
REGION TYPE VIRTUAL
CG backing stores 30.9M
CG image 12K
CG raster data 128K
CG shared images 1256K
CoreGraphics 16K
CoreImage 4K
CoreServices 8068K
MALLOC 47.1M
Memory tag=240 4K
Memory tag=242 12K
Memory tag=243 4K
Memory tag=251 8K
OpenCL 8K
STACK GUARD 56.0M
Stack 9752K
VM_ALLOCATE 16.1M
__CI_BITMAP 80K
__DATA 22.8M
__IMAGE 528K
__LINKEDIT 50.4M
__TEXT 158.4M
__UNICODE 544K
mapped file 40.9M
shared memory 308K
TOTAL 443.0M
Crash in Automix editor:
Process: VirtualDJ [1345]
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Code Type: X86-64 (Native)
Date/Time: 2014-05-28 11:52:00.560 -0400
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 11885030 sec
Crashes Since Last Report: 11
Per-App Interval Since Last Report: 37829 sec
Per-App Crashes Since Last Report: 3
Anonymous UUID: 72665262-1EEC-4FFF-ADFA-EDAD299641E5
Crashed Thread: 11 com.apple.audio.IOThread.client
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
objc[1345]: garbage collection is OFF
Assertion failed: (n>0), function _getBuffer, file /Users/stephane/Documents/atomix/virtualdj/source/AutomixEditor.cpp, line 540.
Thread 0:: Dispatch queue: com.apple.main-thread
5 com.apple.HIToolbox 0x00007fff855892bf RunCurrentEventLoopInMode + 277
6 com.apple.HIToolbox 0x00007fff8559056d ReceiveNextEventCommon + 355
7 com.apple.HIToolbox 0x00007fff855903fa BlockUntilNextEventMatchingListInMode + 62
8 com.apple.AppKit 0x00007fff8308e779 _DPSNextEvent + 659
9 com.apple.AppKit 0x00007fff8308e07d -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
10 com.apple.AppKit 0x00007fff8308a9b9 -[NSApplication run] + 470
11 com.atomixproductions.virtualdj 0x000000010b7c3834 0x10b3ec000 + 4028468
12 com.atomixproductions.virtualdj 0x000000010b9f4db4 0x10b3ec000 + 6327732
13 com.atomixproductions.virtualdj 0x000000010b971bf5 0x10b3ec000 + 5790709
14 com.atomixproductions.virtualdj 0x000000010b93f191 0x10b3ec000 + 5583249
15 com.atomixproductions.virtualdj 0x000000010b78c84a 0x10b3ec000 + 3803210
16 com.atomixproductions.virtualdj 0x000000010b9a0437 0x10b3ec000 + 5981239
17 com.atomixproductions.virtualdj 0x000000010b4d39a2 0x10b3ec000 + 948642
18 com.atomixproductions.virtualdj 0x000000010b3edf04 0x10b3ec000 + 7940
Thread 2:
2 com.atomixproductions.virtualdj 0x000000010b4c8c38 0x10b3ec000 + 904248
3 com.atomixproductions.virtualdj 0x000000010b3f4203 0x10b3ec000 + 33283
4 com.atomixproductions.virtualdj 0x000000010b3f41cd 0x10b3ec000 + 33229
Thread 3:
2 com.atomixproductions.virtualdj 0x000000010b4c8c72 0x10b3ec000 + 904306
Thread 4:
Thread 5:
Thread 6:
Thread 7:
1 com.atomixproductions.virtualdj 0x000000010b3fc6d5 0x10b3ec000 + 67285
2 com.atomixproductions.virtualdj 0x000000010b3f41f9 0x10b3ec000 + 33273
3 com.atomixproductions.virtualdj 0x000000010b3f41cd 0x10b3ec000 + 33229
Thread 8:
2 com.apple.audio.midi.CoreMIDI 0x000000010d24f5be XServerMachPort::ReceiveMessage(int&, void*, int&) + 96
3 com.apple.audio.midi.CoreMIDI 0x000000010d270653 MIDIProcess::RunMIDIInThread() + 207
4 com.apple.audio.midi.CoreMIDI 0x000000010d25096a XThread::RunHelper(void*) + 10
5 com.apple.audio.midi.CoreMIDI 0x000000010d250396 CAPThread::Entry(CAPThread*) + 98
Thread 9:
2 com.atomixproductions.virtualdj 0x000000010bcd1058 0x10b3ec000 + 9326680
Thread 10:
6 com.atomixproductions.virtualdj 0x000000010bcd181d 0x10b3ec000 + 9328669
Thread 11 Crashed:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff879fdce2 __pthread_kill + 10
1 libsystem_c.dylib 0x00007fff8a72b7d2 pthread_kill + 95
2 libsystem_c.dylib 0x00007fff8a71ca7a abort + 143
3 libsystem_c.dylib 0x00007fff8a74f5de __assert_rtn + 146
4 com.atomixproductions.virtualdj 0x000000010b55ee0c 0x10b3ec000 + 1519116
5 com.atomixproductions.virtualdj 0x000000010b68c57d 0x10b3ec000 + 2753917
6 com.atomixproductions.virtualdj 0x000000010b69fb87 0x10b3ec000 + 2833287
7 com.atomixproductions.virtualdj 0x000000010b43db2a 0x10b3ec000 + 334634
8 com.atomixproductions.virtualdj 0x000000010b43da8f 0x10b3ec000 + 334479
9 com.atomixproductions.virtualdj 0x000000010b6d8f3a 0x10b3ec000 + 3067706
10 com.atomixproductions.virtualdj 0x000000010b6d89d4 0x10b3ec000 + 3066324
11 com.apple.audio.CoreAudio 0x00007fff8f0649fa HALC_ProxyIOContext::IOWorkLoop() + 2058
12 com.apple.audio.CoreAudio 0x00007fff8f064151 HALC_ProxyIOContext::IOThreadEntry(void*) + 73
13 com.apple.audio.CoreAudio 0x00007fff8f06400c HALB_IOThread::Entry(void*) + 78
14 libsystem_c.dylib 0x00007fff8a7298bf _pthread_start + 335
15 libsystem_c.dylib 0x00007fff8a72cb75 thread_start + 13
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 11 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x000000011246b338 rdx: 0x0000000000000000
rdi: 0x000000000000910b rsi: 0x0000000000000006 rbp: 0x000000011246b360 rsp: 0x000000011246b338
r8: 0x00007fff74295fb8 r9: 0x000000000000021c r10: 0x00007fff879fdd0a r11: 0xffffff80002dad60
r12: 0x000000010c765199 r13: 0x000000010d52a000 r14: 0x000000011246c000 r15: 0x000000010c7651a4
rip: 0x00007fff879fdce2 rfl: 0x0000000000000246 cr2: 0x000000010d52a000
Logical CPU: 0
Binary Images:
0x10b3ec000 - 0x10c9c8f4f +com.atomixproductions.virtualdj (8.0.0 - 8.0.1806) <01D356B9-3508-32BF-9D21-07BA7F2D8164> /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
0x10d21b000 - 0x10d228ff7 +com.googlecode.google-breakpad (??? - 1.0) <9A5F89A4-5EA3-339F-BC47-6DF8D64238C6> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
0x10d240000 - 0x10d291ff7 com.apple.audio.midi.CoreMIDI (1.8 - 42) <10BAC42F-ACFE-3EBC-869A-2847A0770CE8> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10d2bc000 - 0x10d2e1ff7 +breakpadUtilities.dylib (??? - ???) <753EEC59-5853-36C1-BD7A-CB38123F77E5> /Applications/VirtualDJ 8.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib
0x10ec6e000 - 0x10ec7cfff libGPUSupport.dylib (??? - ???) <9FF8DDA2-7CB1-3888-8AAE-227C7691CB98> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x10ec83000 - 0x10ecb1ff7 GLRendererFloat (??? - ???) <06CA5D0B-BC5F-3CC7-836D-A02F7DB92BE8> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x10ecba000 - 0x10ecc4fef libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <4572AD1E-D1D1-3412-AFCC-D37037B1FAB5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x10ecca000 - 0x10eccdff7 libCoreFSCache.dylib (??? - ???) <0D155750-7910-32C5-8327-924FC1089442> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x10f2f1000 - 0x10f2f1ff3 +cl_kernels (??? - ???) <823460DE-EC2A-4F04-9254-3C0DE2F2593E> cl_kernels
0x10f2ff000 - 0x10f2ffffb +cl_kernels (??? - ???) <998F7014-FF87-4D51-A859-A6A8CE928BBA> cl_kernels
0x1109d1000 - 0x1109d5fff com.apple.audio.AudioIPCPlugIn (1.2.3 - 1.2.3) <F94D690D-3196-3B01-B798-09708367D28D> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x1109da000 - 0x1109dffff com.apple.audio.AppleHDAHALPlugIn (2.2.5 - 2.2.5a5) <4EC4981B-68AE-357E-960F-3D4603A61E9F> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x110a04000 - 0x110a08ff7 libFontRegistryUI.dylib (??? - ???) <6EFD0158-64F7-3A65-92E3-875AD0382A5C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x11487f000 - 0x114a37fff GLEngine (??? - ???) <59179FEC-D0E2-38B3-BD49-765506A645AC> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x114a6e000 - 0x114bc8fff libGLProgrammability.dylib (??? - ???) <90390984-70BC-365C-AB3E-16C35C4240CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x114bfa000 - 0x114fe1fe7 com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.32.12 - 7.3.2) <5C9C9474-BA99-33A6-BAD8-628224491FED> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsGLDriver
0x118b9b000 - 0x118bbafff com.apple.IOFireWireLib (4.4.8 - 4.4.8) <51398B7F-1BB2-3461-9582-1ABF3F35B635> /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
0x121708000 - 0x1217a7ff7 unorm8_bgra.dylib (2.0.19 - compatibility 1.0.0) <47DA7D73-C52D-322F-A08F-4DB320A65373> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff6afec000 - 0x7fff6b020baf dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
0x7fff83059000 - 0x7fff8307dfff com.apple.RemoteViewServices (1.5 - 44.2) <A0417D7F-22E9-3FD8-AC55-67654D8E93EB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff83086000 - 0x7fff83c8cfff com.apple.AppKit (6.7.5 - 1138.51) <44417D02-6123-3FC3-A119-CE51BB4C3006> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff83c8d000 - 0x7fff83c8efff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
0x7fff83c8f000 - 0x7fff83da8fff com.apple.DesktopServices (1.6.5 - 1.6.5) <5E7DD5F4-B4DA-3F75-A14A-3494E81CFBA0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff83e45000 - 0x7fff83e45fff com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff83f7f000 - 0x7fff841a9fe7 com.apple.CoreData (104.1 - 358.14) <6BB64605-8DA7-337D-A2AB-A3346A421CBD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff841aa000 - 0x7fff842b6fef libcrypto.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <FB999E54-C9BC-3A6D-9FE5-BFCC236775ED> /usr/lib/libcrypto.0.9.8.dylib
0x7fff842b7000 - 0x7fff842befff libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <0AB51EE2-E914-358C-AC19-47BC024BDAE7> /usr/lib/system/libcopyfile.dylib
0x7fff842d6000 - 0x7fff842dfff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
0x7fff8432b000 - 0x7fff84336fff com.apple.CommonAuth (2.2 - 2.0) <4F5302A5-867A-3F2E-9E4B-98FA011678F8> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff84337000 - 0x7fff8433efff libGFXShared.dylib (??? - ???) <D3598924-B167-372E-8C9F-1BBF68852542> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8434b000 - 0x7fff84366fff libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <DDB91E75-A2FA-331F-8069-999127AC6A9D> /usr/lib/libexpat.1.dylib
0x7fff84367000 - 0x7fff84369ff7 com.apple.print.framework.Print (7.4 - 247.3) <626C58D5-2841-3329-8C32-9F4A8353F3E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff8438d000 - 0x7fff84412ff7 com.apple.Heimdal (2.2 - 2.0) <52B0F371-D272-3C8E-B42F-04D3FDD8AD0D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff84413000 - 0x7fff84420fff com.apple.CrashReporterSupport (10.7.4 - 353) <6044CFB6-939E-3C73-BFBB-A8BBC096F135> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff84421000 - 0x7fff84447fff com.apple.framework.familycontrols (3.0 - 300) <6F0C58C0-22E7-3877-8CFA-1ED0CB3CE38B> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff84448000 - 0x7fff844a0ff7 libTIFF.dylib (??? - ???) <CF2005B6-5C29-3DCF-BDC2-7DB114ECD7A1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff844ff000 - 0x7fff8450dfff libdispatch.dylib (187.10.0 - compatibility 1.0.0) <8E03C652-922A-3399-93DE-9EA0CBFA0039> /usr/lib/system/libdispatch.dylib
0x7fff8450e000 - 0x7fff84537fff com.apple.CoreVideo (1.7 - 70.3) <9A9D4058-9935-3B0A-B1A6-27EB78D02249> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff850d6000 - 0x7fff850e1ff7 com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <6540EAF2-E3BF-3D2E-B4C1-F106180D6F20> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff850e9000 - 0x7fff8512dff7 com.apple.MediaKit (12 - 602) <0C2CBEDA-412F-3DDF-9C74-44114E5E0DB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8512e000 - 0x7fff85141ff7 libCRFSuite.dylib (??? - ???) <0B76941F-218E-30C8-B6DE-E15919F8DBEB> /usr/lib/libCRFSuite.dylib
0x7fff85142000 - 0x7fff8516eff7 com.apple.CoreServicesInternal (113.20 - 113.20) <786118E6-7D7E-3016-9FD5-A7CE411A251F> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff8516f000 - 0x7fff85269ff7 com.apple.DiskImagesFramework (10.7.4 - 331.7) <BEBA6D78-08E0-3B99-B77B-A5CBF3344834> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff8526a000 - 0x7fff8527cff7 libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
0x7fff8527d000 - 0x7fff85281ff7 com.apple.CommonPanels (1.2.5 - 94) <37C6540B-F8D1-355A-806C-F93D8FB522AB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff85282000 - 0x7fff852bdfff com.apple.LDAPFramework (3.2 - 120.2) <275D4298-C435-3E98-AA25-95D9D0A56550> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff852be000 - 0x7fff852fefe7 libGLImage.dylib (??? - ???) <0B7DAB2B-F1C6-39C7-B864-61EF683B6656> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff85312000 - 0x7fff85312fff libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
0x7fff85313000 - 0x7fff85316fff libCoreVMClient.dylib (??? - ???) <28CB0F3F-A202-391F-8CAC-FC9A1398A962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8533e000 - 0x7fff85382ff7 libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <B2A38D2C-7E82-34C5-8896-48C37B0E64A3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff85383000 - 0x7fff85387fff libdyld.dylib (195.5.0 - compatibility 1.0.0) <380C3F44-0CA7-3514-8080-46D1C9DF4FCD> /usr/lib/system/libdyld.dylib
0x7fff85586000 - 0x7fff85586fff com.apple.Carbon (153 - 153) <C1A30E01-E113-38A0-95CA-99360F92A37A> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff85587000 - 0x7fff858b3fff com.apple.HIToolbox (1.9 - ???) <CCB32DEA-D0CA-35D1-8019-E599C8007AB6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff858b4000 - 0x7fff85a11fff com.apple.audio.toolbox.AudioToolbox (1.7.3 - 1.7.3) <5F1E4695-BC74-3ADD-8345-627BCD68201A> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff85a14000 - 0x7fff85a22fff com.apple.NetAuth (3.1 - 3.1) <FE7EC4D7-5632-3B8D-9094-A0AC8D60EDEE> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff85a23000 - 0x7fff85aeaff7 com.apple.ColorSync (4.7.4 - 4.7.4) <590AFCDA-F10E-31FE-9B01-DA5FFE74C2BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff85aeb000 - 0x7fff85af0fff libcache.dylib (47.0.0 - compatibility 1.0.0) <1571C3AB-BCB2-38CD-B3B2-C5FC3F927C6A> /usr/lib/system/libcache.dylib
0x7fff85af1000 - 0x7fff85af6fff libGIF.dylib (??? - ???) <58A4492D-AAE7-3B8F-8B06-62867471A3EE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff85afc000 - 0x7fff85be0ff7 com.apple.CoreServices.OSServices (478.50 - 478.50) <3D6AA4EF-C601-36C7-8F3A-A00964F01759> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff85be1000 - 0x7fff85be7fff libmacho.dylib (800.0.0 - compatibility 1.0.0) <165514D7-1BFA-38EF-A151-676DCD21FB64> /usr/lib/system/libmacho.dylib
0x7fff8601c000 - 0x7fff86449fff libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff86676000 - 0x7fff8667bfff com.apple.OpenDirectory (10.7 - 146) <A674AB55-6E3D-39AE-9F9B-9865D0193020> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff8667c000 - 0x7fff866a5fff libJPEG.dylib (??? - ???) <DFD81B8F-F4CB-347B-92B8-1AFFDA924A9B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff866a6000 - 0x7fff866b3fff libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <72C53E7B-C222-3BE5-9984-FDC328CC4846> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff866b4000 - 0x7fff866b4fff com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff86d36000 - 0x7fff8702bff7 com.apple.security (7.0 - 55148.6) <4535E500-973A-3BA7-AF65-DF5CF0658F02> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8702c000 - 0x7fff870d1fff com.apple.ink.framework (10.7.5 - 113) <1AE6676D-490A-36C2-B6CC-00F93AEB31DE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff870d2000 - 0x7fff87174fff com.apple.securityfoundation (5.0 - 55116) <A9311EF6-B7F7-3DA5-84E8-21BC9B2C3C69> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff87271000 - 0x7fff872a1ff7 com.apple.DictionaryServices (1.2.1 - 158.3) <5E2EBBFD-D520-3379-A431-11DAA844B8D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff872a2000 - 0x7fff872a8ff7 libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
0x7fff872a9000 - 0x7fff872c5ff7 com.apple.GenerationalStorage (1.0 - 126.1) <509F52ED-E54B-3FEF-B3C2-759387B826E6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff872c6000 - 0x7fff872d8ff7 libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
0x7fff872d9000 - 0x7fff872defff libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
0x7fff87346000 - 0x7fff87394fff libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
0x7fff873be000 - 0x7fff873cbff7 libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <3373D310-3B10-3DD1-B754-B7B138CD448D> /usr/lib/libbz2.1.0.dylib
0x7fff874b9000 - 0x7fff877dbfff com.apple.JavaScriptCore (7534.57 - 7534.57.3) <3A04B8FC-CFA6-3AEB-8FDF-B0525B5A4C82> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff877dc000 - 0x7fff87838ff7 com.apple.HIServices (1.21 - ???) <B012EE97-D1CD-3F4B-812D-9AC7E6852FE6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff87839000 - 0x7fff8783bfff libquarantine.dylib (36.7.0 - compatibility 1.0.0) <8D9832F9-E4A9-38C3-B880-E5210B2353C7> /usr/lib/system/libquarantine.dylib
0x7fff878fc000 - 0x7fff87901fff libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
0x7fff87902000 - 0x7fff87919fff com.apple.CFOpenDirectory (10.7 - 146) <E71AE4A2-F72B-35F2-9043-9F45CF75F11A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff87946000 - 0x7fff87988ff7 libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <BB770C22-8C57-365A-8716-4A3C36AE7BFB> /usr/lib/system/libcommonCrypto.dylib
0x7fff87989000 - 0x7fff879e4ff7 com.apple.opencl (2.0.19 - 2.0.19) <B05BF605-73B8-328F-A228-6FA59E1FC73A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff879e7000 - 0x7fff87a07fff libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <66C9F9BD-C7B3-30D4-B1A0-03C8A6392351> /usr/lib/system/libsystem_kernel.dylib
0x7fff87a08000 - 0x7fff8873ffff com.apple.WebCore (7534.57 - 7534.57.7) <33FCF30A-08C5-3169-B3B0-3A9462FA1A0D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff88740000 - 0x7fff888a7ff7 com.apple.CFNetwork (520.5.3 - 520.5.3) <1C11C214-1C70-3358-A709-69C84D999DB8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff888a8000 - 0x7fff888d0fff com.apple.PerformanceAnalysis (1.11 - 11) <8D4C6382-DD92-37A2-BCFC-E89951320848> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff888d1000 - 0x7fff889affff com.apple.DiscRecording (6.0.4 - 6040.4.1) <E6D5835F-EE3C-3814-A2EE-6962B5570EF1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff889fd000 - 0x7fff88a80fef com.apple.Metadata (10.7.0 - 627.37) <B9BEB598-B6F2-3BFF-A8F3-C3C87CD076AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff88a81000 - 0x7fff88f48fff FaceCoreLight (1.4.7 - compatibility 1.0.0) <BDD0E1DE-CF33-3AF8-B33B-4D1574CCC19D> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x7fff88fe1000 - 0x7fff88fe2ff7 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <739E6C83-AA52-3C6C-A680-B37FE2888A04> /usr/lib/system/libremovefile.dylib
0x7fff88fe3000 - 0x7fff89022fff com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff89023000 - 0x7fff89035ff7 libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
0x7fff8909f000 - 0x7fff8909ffff libOpenScriptingUtil.dylib (??? - ???) <A7847713-F410-39C0-884F-A7188A18E742> /usr/lib/libOpenScriptingUtil.dylib
0x7fff890e7000 - 0x7fff890e9fff com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff890ea000 - 0x7fff890fffff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff89a32000 - 0x7fff89d4bfff com.apple.Foundation (6.7.2 - 833.25) <22AAC369-B63C-3C55-8AC6-C3ECBA44DA7B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff89dfe000 - 0x7fff89e04fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff89e24000 - 0x7fff89e32ff7 libkxld.dylib (??? - ???) <01161870-E3B3-3F87-BA4A-0AA7A081F409> /usr/lib/system/libkxld.dylib
0x7fff89e34000 - 0x7fff89eaafff com.apple.CoreSymbolication (2.2 - 73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff89eba000 - 0x7fff89ebbfff liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
0x7fff89f8b000 - 0x7fff89fc6fff libsystem_info.dylib (??? - ???) <35F90252-2AE1-32C5-8D34-782C614D9639> /usr/lib/system/libsystem_info.dylib
0x7fff89fe6000 - 0x7fff8a0edfe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <EE02BB01-64C9-304D-9719-A35F5CD6D04C> /usr/lib/libsqlite3.dylib
0x7fff8a0ee000 - 0x7fff8a0eefff com.apple.Cocoa (6.6 - ???) <7EC4D759-B2A6-3A99-AC75-809FED1500C6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8a0ef000 - 0x7fff8a10cff7 com.apple.openscripting (1.3.3 - ???) <F5E34F54-CE85-334B-8F25-53581D43960C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8a1ba000 - 0x7fff8a1c5ff7 libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
0x7fff8a1c6000 - 0x7fff8a1c9ff7 com.apple.securityhi (4.0 - 1) <7146CB8E-B754-3B0E-A74E-77E9138A81C5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8a5a6000 - 0x7fff8a685fff com.apple.ImageIO.framework (3.1.2 - 588) <37F047A9-48E3-3AF7-8931-462D63BE6121> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8a686000 - 0x7fff8a694fff com.apple.HelpData (2.1.2 - 72.2) <363E36C5-F7C0-34A6-83D3-97C8FB6511F0> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff8a695000 - 0x7fff8a699fff libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <35D606B1-7AD9-38E3-A2A9-E92B904BDDE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff8a69a000 - 0x7fff8a6daff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <7D2E5016-A960-3ADE-B042-F74063E79550> /usr/lib/libcups.2.dylib
0x7fff8a6db000 - 0x7fff8a7b8fef libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
0x7fff8ac03000 - 0x7fff8ac09fff IOSurface (??? - ???) <77C6757B-D357-3E34-9424-48F962B5CC9C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff8ac0a000 - 0x7fff8ac0afff com.apple.Accelerate (1.7 - Accelerate 1.7) <82DDF6F5-FBC3-323D-B71D-CF7ABC5CF568> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8ac4c000 - 0x7fff8ac79fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <7BEBB139-50BB-3112-947A-F4AA168F991C> /usr/lib/libSystem.B.dylib
0x7fff8ac7a000 - 0x7fff8ac8eff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff8ac8f000 - 0x7fff8acaefff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <0635C52D-DD53-3721-A488-4C6E95607A74> /usr/lib/libresolv.9.dylib
0x7fff8acaf000 - 0x7fff8ad45ff7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) <642D8D54-F9F5-3FBB-A96C-EEFE94C6278B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8aec3000 - 0x7fff8af47ff7 com.apple.ApplicationServices.ATS (317.13.0 - ???) <A05126F9-7DC9-3EA7-8D94-53C6113730C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8b23a000 - 0x7fff8b40eff7 com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8b40f000 - 0x7fff8b413fff libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
0x7fff8b414000 - 0x7fff8b4aeff7 com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8b4af000 - 0x7fff8b7cbfff com.apple.CoreServices.CarbonCore (960.25 - 960.25) <4FC1AB30-022C-3C67-AC46-FDCBFCB7EEDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff8b7cc000 - 0x7fff8b818ff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <0A7F1982-B4EA-3424-A0C7-FE46C6224F03> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff8b819000 - 0x7fff8b90efff libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
0x7fff8b90f000 - 0x7fff8ba1cfff libJP2.dylib (??? - ???) <1CF69239-3D3D-30CE-AC7B-C7E8C9166BC2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff8ba3a000 - 0x7fff8ba44ff7 liblaunch.dylib (392.39.0 - compatibility 1.0.0) <8C235D13-2928-30E5-9E12-2CC3D6324AE2> /usr/lib/system/liblaunch.dylib
0x7fff8bdf4000 - 0x7fff8be27ff7 com.apple.GSS (2.2 - 2.0) <C86012C5-B613-3199-B1B3-A1494EE5E43C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff8be72000 - 0x7fff8bec4ff7 libGLU.dylib (??? - ???) <DB906997-0F70-3469-BA0E-2F1DDBEAD8D5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8bf54000 - 0x7fff8bfbfff7 com.apple.framework.IOKit (2.0 - ???) <FE838BB6-D42E-3291-A1A0-6F53FC970261> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8bfc0000 - 0x7fff8c033fff libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
0x7fff8c034000 - 0x7fff8c618fff libBLAS.dylib (??? - ???) <C34F6D88-187F-33DC-8A68-C0C9D1FA36DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff8c619000 - 0x7fff8c689fff com.apple.datadetectorscore (3.0 - 179.4) <9C01D16F-75A9-3BDD-B91A-F0F32261A2E7> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8c68a000 - 0x7fff8c691fff com.apple.CommerceCore (1.0 - 17.1) <B6BFA182-9DC9-3543-89AE-F82EB9AF1CAB> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff8c6b6000 - 0x7fff8c6f0fe7 com.apple.DebugSymbols (2.1 - 87) <ED2B177C-4146-3715-91DF-D99A8ED5449A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8c6f1000 - 0x7fff8c708fff com.apple.MultitouchSupport.framework (231.4 - 231.4) <10A978D1-8781-33F0-BE45-60C9171F7278> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8c709000 - 0x7fff8c893ff7 com.apple.WebKit (7534.57 - 7534.57.7) <15AA1A2E-DCAC-35CE-89DF-0FF7149198CD> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8c894000 - 0x7fff8c89bfff com.apple.NetFS (4.0 - 4.0) <433EEE54-E383-3505-9154-45B909FD3AF0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff8c89c000 - 0x7fff8c8fcfff libvDSP.dylib (325.4.0 - compatibility 1.0.0) <3A7521E6-5510-3FA7-AB65-79693A7A5839> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8c94f000 - 0x7fff8c95eff7 libxar-nossl.dylib (??? - ???) <A6ABBFB9-E4ED-38AD-BBBB-F9958B9CEFB5> /usr/lib/libxar-nossl.dylib
0x7fff8cafa000 - 0x7fff8cb09fff com.apple.opengl (1.8.1 - 1.8.1) <51B34133-CEE3-3FC6-82AC-ADF567AE673C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8cb0a000 - 0x7fff8cbeee5f libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <871E688B-CF57-3BC7-80D6-F6476DFF109B> /usr/lib/libobjc.A.dylib
0x7fff8cbef000 - 0x7fff8cbf0ff7 libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
0x7fff8d092000 - 0x7fff8d145ff7 com.apple.CoreText (220.22.0 - ???) <A7A1096F-A211-3775-BA33-08FE98D27F08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8d146000 - 0x7fff8d19aff7 com.apple.ScalableUserInterface (1.0 - 1) <33563775-C662-313D-B7FA-3D575A9F3D41> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x7fff8d19b000 - 0x7fff8d1a3fff libsystem_dnssd.dylib (??? - ???) <584B321E-5159-37CD-B2E7-82E069C70AFB> /usr/lib/system/libsystem_dnssd.dylib
0x7fff8d1a4000 - 0x7fff8d1dffff libssl.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <B5120F7F-6FD7-3E0B-AAB8-E9A8D72451BC> /usr/lib/libssl.0.9.8.dylib
0x7fff8d1e0000 - 0x7fff8d234fff libFontRegistry.dylib (??? - ???) <60FF9C2C-5E44-3C49-8A08-F26101898F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff8d235000 - 0x7fff8d275fff libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
0x7fff8d2a7000 - 0x7fff8d2e8fff com.apple.QD (3.40.1 - ???) <13ACC7F4-B004-3370-B575-6D06447EE428> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8d2e9000 - 0x7fff8d41ffff com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff8d420000 - 0x7fff8d522fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <AFBB22B7-07AE-3F2E-B88C-70BEEBFB8A86> /usr/lib/libxml2.2.dylib
0x7fff8d7ac000 - 0x7fff8d7c9fff libxpc.dylib (77.19.0 - compatibility 1.0.0) <9F57891B-D7EF-3050-BEDD-21E7C6668248> /usr/lib/system/libxpc.dylib
0x7fff8d7ca000 - 0x7fff8d82cff7 com.apple.Symbolication (1.3 - 91) <B072970E-9EC1-3495-A1FA-D344C6E74A13> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff8d82d000 - 0x7fff8d8ceff7 com.apple.LaunchServices (480.42 - 480.42) <A69F9426-05CE-3312-89FD-BC063DA66DBF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8d8cf000 - 0x7fff8d937ff7 com.apple.coreui (1.2.2 - 165.11) <9316266A-39CA-3EC7-9C9E-726462CEFF4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff8d938000 - 0x7fff8d963ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
0x7fff8d964000 - 0x7fff8d97aff7 com.apple.ImageCapture (7.1.0 - 7.1.0) <1AD40E02-2126-377B-A0D2-CBB21D932558> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff8dc46000 - 0x7fff8dc47fff libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8dec1000 - 0x7fff8dec2ff7 libsystem_sandbox.dylib (??? - ???) <5459F293-E1F2-33B3-B9B2-2ABB7B915B62> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8dec3000 - 0x7fff8df09fff libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <066449E4-406B-3ABC-9DB8-E62777498154> /usr/lib/libcurl.4.dylib
0x7fff8df0a000 - 0x7fff8df11fff libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <1116CD6D-E7AD-375F-A691-B9DF6609FEAD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x7fff8df12000 - 0x7fff8e017fff libFontParser.dylib (??? - ???) <D2E56B6E-3182-3667-A78C-4172C435523A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8e018000 - 0x7fff8e01bfff com.apple.help (1.3.2 - 42) <BF14DE49-F7E8-336F-81FB-BBDF2DB3AC09> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8e01c000 - 0x7fff8e01cfff com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8e3c8000 - 0x7fff8e3ecfff com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8e3ed000 - 0x7fff8e403fff libGL.dylib (??? - ???) <A4876AE9-DDFE-3B9A-874E-09BC29D46C39> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8e404000 - 0x7fff8e404fff com.apple.ApplicationServices (41 - 41) <89B6AD5B-5C75-3E83-8C2B-AA7F4C55E400> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8e405000 - 0x7fff8e407fff libCVMSPluginSupport.dylib (??? - ???) <982F1ED4-3CBB-3161-8BEA-8A980C27FCC1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8e408000 - 0x7fff8e60afff libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <0176782F-9526-3905-813A-7A5676EC2C86> /usr/lib/libicucore.A.dylib
0x7fff8e60b000 - 0x7fff8e60bfff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8e69f000 - 0x7fff8f03da27 com.apple.CoreGraphics (1.600.0 - ???) <576777EA-921B-3D94-98C3-40A9CF8EBD18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8f03e000 - 0x7fff8f0a6ff7 com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <9987DC46-2A96-3BA0-B88B-04E573C0AD9B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8f850000 - 0x7fff8f853fff libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8f8a8000 - 0x7fff8f8adff7 libsystem_network.dylib (??? - ???) <5DE7024E-1D2D-34A2-80F4-08326331A75B> /usr/lib/system/libsystem_network.dylib
0x7fff8f8da000 - 0x7fff8f8dbfff libunc.dylib (24.0.0 - compatibility 1.0.0) <337960EE-0A85-3DD0-A760-7134CF4C0AFF> /usr/lib/system/libunc.dylib
0x7fff8f925000 - 0x7fff8f9a0ff7 com.apple.print.framework.PrintCore (7.1 - 366.3) <C5F39A82-0E77-3AD6-906A-20DD2EE8D374> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8f9a1000 - 0x7fff8fa17ff7 libc++.1.dylib (28.4.0 - compatibility 1.0.0) <A24FC3DA-4FFA-3DD2-9DCC-2B8D1B3BF97C> /usr/lib/libc++.1.dylib
0x7fff8fa53000 - 0x7fff8fbf3ff7 com.apple.QuartzCore (1.7 - 270.5) <19E5E0AB-DAA9-3F97-988C-D9A46AFB9C04> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff8fbf4000 - 0x7fff8fc15fff libPng.dylib (??? - ???) <E2B52527-4D0C-3595-BB13-8E8EF364E998> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8fc16000 - 0x7fff8fc45fff com.apple.shortcut (2.1 - 2.1) <BE0AB36A-6911-356B-8784-D39175ACAF55> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff8fd82000 - 0x7fff8fff6fff com.apple.CoreImage (7.99.1 - 1.0.1) <4BB09B79-275B-364C-9466-0FF36ABB1218> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 9
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2661
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=215.3M resident=103.8M(48%) swapped_out_or_unallocated=111.4M(52%)
Writable regions: Total=863.4M written=664.2M(77%) resident=773.9M(90%) swapped_out=0K(0%) unallocated=89.5M(10%)
REGION TYPE VIRTUAL
CG backing stores 5584K
CG image 48K
CG raster data 192K
CoreGraphics 16K
CoreImage 4K
CoreServices 8068K
IOKit 42.8M
MALLOC 771.4M
MALLOC guard page 48K
Memory tag=240 4K
Memory tag=242 12K
OpenCL 16K
OpenGL GLSL 896K
STACK GUARD 56.1M
Stack 17.2M
VM_ALLOCATE 16.3M
__CI_BITMAP 80K
__DATA 22.8M
__IMAGE 528K
__LINKEDIT 52.0M
__TEXT 163.3M
__UNICODE 544K
mapped file 46.6M
shared memory 2044K
TOTAL 1.2G
TOTAL, minus reserved VM space 1.2G
Model: MacBookPro8,1, BootROM MBP81.0047.B27, 2 processors, Intel Core i5, 2.4 GHz, 8 GB, SMC 1.68f99
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x802C, 0x31364A54463531323634485A2D3147344D31
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x802C, 0x31364A54463531323634485A2D3147344D31
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: TOSHIBA MK5065GSXF, 500.11 GB
Serial ATA Device: OPTIARC DVD RW AD-5970H
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 8
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
Are any of my crash issues being looked at? I know you guys are busy but I have had no communications whatsoever since posting what was requested with the issues I have been detailing.
BTW all the testing I'm doing is just with the Software I haven't even begun to connect to external mixer/usb soundcard/CD decks (MIDI).
Thanks in advance.
Please make sure your software is updated.
And change the crashLevel setting to 0 (if not already), so that the crashes get uploaded automatically to our servers.
thank you.
thank you.
yes crashlevel is set to 0. I am on 1806 now, but I can't get the latest, even from the cnet servers it only allows for 1806
djdad wrote :
https://virtualdj.com/forums/188981/General_Discussion/_NEWS__VirtualDJ_8__get_beta_builds__option.html
Thanks.. I have added the beta builds to my profile,
