Hello, I installed yesterday VDJ8, I have issues and few questions to ask, it will be greatful if someone can reply me:
1. I mapped the NS7 to make it work with 4 decks, can you tell me how can i do it with the NSFX also, because i can the NS7 with 4 decks and after plug-in the NSFX, i can only use 2 decks. Can you help me?
2. How can i change the gain's volume in the software? I tried to see in advanced controls but didn't find it.
3. The UV Meters don't show the real output when the Master Volume is on 0. What can I do?
4. Is there a possibility to have the effects page? How?
5. Is someone made a mapper for VDJ8 to make the NS7 platters at the same pitch as the song?
6. Is there a code for adding 5 more cues on the NS7? 1 and 6, 2 and 7 ...
I wish I could have solutions for it. Thank you in advance :)
geposted Thu 22 May 14 @ 6:20 am
Nobody to reply?
geposted Thu 22 May 14 @ 9:21 am
They have bigger issues to address at this time, I would assume.
geposted Thu 22 May 14 @ 9:43 am
Ooh, really? But i wish they will correct all those things.
Do you have an answer for the 5th question?
geposted Thu 22 May 14 @ 9:50 am
2. Select the mixer panel in the skin...there you can change the gain
4: Just klick on the effekts plulldown menue for aoverview
geposted Thu 22 May 14 @ 11:00 am
Thank you, but the gain had been changed from the VDJ7, is it possible to recode the gain to match it with the same as VDJ7?
geposted Thu 22 May 14 @ 11:03 am
Anyone?
geposted Sat 24 May 14 @ 4:16 am
I'm not sure exactly what you mean by "the gain has been changed" but the output headroom can be adjusted with the zerodb config setting.
There also other gain related settings in the config (search 'gain').
geposted Sat 24 May 14 @ 4:33 am
Warning ! In V8 not disable Limiter
I recommend:
in settings .. Gain to AUTO
ZeroDB ... correct 0.70
I recommend:
geposted Sat 24 May 14 @ 5:44 am
Efects page not Exist in V8 as V7 .
geposted Sat 24 May 14 @ 5:46 am
groovindj wrote :
I'm not sure exactly what you mean by "the gain has been changed" .
The gain value in VDJ8 is louder than the gain value in VDJ7, it means the gain in VDJ8 was boost.
geposted Wed 28 May 14 @ 6:37 am
Select an effect from the effect list on a deck - in the popup menu don't click the effect - use the small icon right beside the effect to open the effects GUI in the Browser section.
Greets, Heiko
Greets, Heiko
geposted Wed 28 May 14 @ 6:42 am
