Topic: plug ins
hi all I'm on a macbook pro running mavericks with virtual 8,
i downloaded a few plugins i really wanted to use like sbdj scroll text and clip bank but when i try to install it it just opens up a box of code in terminal. i even tried dragging the unix executable file into the video effects folder under plugins in vdj in my documents...can someone explain how to do this please.
thanks
mike
geposted Thu 22 May 14 @ 12:16 pm
The plugins you mention:
Clipbank is no longer support in version 8 - you can use the sampler for video and image sample.
Scrolltext requires updated by the plugin developer, you will have to be patient for this,
thanks man....can you loop the sample?
Yes - you need to use the sample editor.
Page 72 of the Manual ;)
